Hey guys I am in the process of getting everything together for my 26 conversion into my s13. This will be a dedicated drift car so I am chasing response over outright power. But I am really keen to go single, as everything is a very tight fit in my bay as I have tubs etc. So if anyone could help with some advice of:
Turbo and Manifold choice
Loose Power Figures
I currently have
R33 block
Block decked, honed, bored, chemically cleaned
Shotpeened rods
ARP rod bolts
ACL forged pistons 20 thou over
Mahle rings
King bearings
Ported and Polished head
Reground cams
ARP head studs
Permaseal head gasket
Custom 7L RWD sump
Sard 700cc injectors
NGK plugs
Tomei oil restrictor
N1 oil pump
Thanks in advance
Edited by Goodfellas
What is your abilty?
as size is dependant on driver quality and chasis setup... the more you progress the more and more grip you chase in the rear (many of us run semis on the rear 265-285) in size end so obviously you need more power to turn them.
For entry level to mid i recommend GT3076 (with the larger rear) or a 10cm T67 is also a killer drift setup for RB26 (i had a few T3 versions around for about $1200)
for mid to high level i recommend Gt3540 or equivalent (we run the blitz K5 which performs better but cost twice as much)
Well I would say I am entry to mid level, my chassis has tubs, removable rad support, full seam welded, and full bolt in cage. Suspension set up is JIC coilovers,adjustable everything blah blah blah... So t67 25g 10cm rear??? thats kinda what i had in mind, any others????
have you actually run one of these turboes?
looks to cheap to be true
yeah 3 or 4 now. I tried one myself for a while before letting a few of my customers buy one off ebay.
Trent, Can we please have some dynographs on this turbo? That would be fantastic!
Also, what is the response of this turbo comparable to?
I am currenlty building up a street RB25 with all the fruit to run between 270-300rwkw and I just might be in the market for a new turbo.... :D
Will be runnig forged bottem end, mildly ported head with upgraded springs, poncams, front facing plenum,haltech platinum ecu etc, etc.
I have a VG30 turbo i was planning on getting highflowed but this looks like a gret option also.
Define "smilar spool" :(
Larger rear housing, larger turbo comp side, that combination dont usually make for 'similar' by my definition :D
I know this, sounds a bit strange but it is honestly the reality - I think the twin scroll setup makes up for a lot of it. The twin scroll GT3582R cars I've been in are honestly feel too good to be true, the guys I know who have gone from single entry to twin scroll GT35 setups have improved spool by around 500rpm (pretty much the difference between an equivalent GT30R and GT35R) and make more midrange torque for an equivalent boost level.
I haven't been in a Skyline with a TS GT35R *yet* but given they are a 6, the gains are only going to be at least as good as the 4cyl ones I've been in. From the cars I've experienced I'd expect 1bar before 4000rpm on an RB25 with good manifolding, and heaps of midrange. Naturally the TS setup on a GT3076R would be better again, but I'd say ridiculous on an RB26.
Think of it this way, twin GT2860-5s have the combined equivalent "wheel" surface area of a T04Z... which spools better?
3076 with a .82 rear housing is good on an rb26 and as other have said you will get about 330kw which is plenty of power
i have one for sale atm because i've decided to upgrade it
Turbo
I am currenlty building up a street RB25 with all the fruit to run between 270-300rwkw and I just might be in the market for a new turbo.... :happy:
will do, away till monday.
6boost manifold. if you have a twin scroll turbo make sure u have a split pulse manifold to compliment
as for the oil pump, this is the easiest option Oil pump gears
I haven't used on but it looks ok. I would confirm the correct width
  • 5 weeks later...
Oh wow! I totally forgot about this thread.
I have ditched the high flow option and I am in the market for either a HKS GT3037 pro s or MHI T67 10cm.
I thought I might as well considering I'm pretty much going all out on the long motor.
Any thoughts or Dyno read outs of either of these turbo's on RB25 would be awesome, thanks Trent.
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
