I haven't been in a Skyline with a TS GT35R *yet* but given they are a 6, the gains are only going to be at least as good as the 4cyl ones I've been in.
After reading one of discopotato's long posts twin scroll is more effective on 4 cylinder engines and less so on 6 cylinders and almost not worth it on an 8 cylinder. Sure it will be helpful on a 6 but I dont think the statement that it will be at least as good as a 4 cylinder is correct.
There is probably a certain amount of theorising with both of our viewpoints, how do you decide he is more correct than I (or vice versa for that matter? I am happy to stay objective...)?
A lot of that will depend on the execution of the whole thing, for example on a V8 - where is the rationale that twin scroll would be less beneficial on a V8 than it would on a 4cyl when a V8 is essentially two 4cylinders? I wrote a big rant ages ago on GTR UK forum regarding the potential benefits of twin twinscroll turbos on a cross plane V8 to combat the effect of the unevenly spaced ignition events on each bank.
Also, I have been in Nissans running twin scroll turbos - just on a TS GT35R to compare with the exact equivalent single entry GT35R... hence restraining opinion. Given Disco doesn't sound like he can provide the same comparison, I'd consider it reckless stating a fact without confirming the theory.
This is the only one i have handy (ie on this comp), full owner built car him and his old man did a great job, went on the dyno with no issues (other than bit of boost creep from the 6 boost mani)
The power graph is not really a good example as the boost curve starts at 14psi and tapers up to the 19psi point, not enough gate pressure but until the owner gets used to it we wont dial it up (the blitz gate and blitz i-color will dial it out a piece of piss).
If it was making the full 19psi by 3600-3800 like the normally do the they make around 220rwkw @ 4k and 270-280rwkw @ 5k etc... with the ramp rate i use, maybe more responsive on a roller.
Are you going up against the mighty discopotato!
Have you seen the length of his posts??
As we all know length DOES count... :P
That is fairly impressive considering the boost issue!
Is that a T3 10cm flanged turbo or a 8cm Mitsubishi flange?!?
Also how much do you think a standard manifold would strangle through mid range and top end?!?
After years of discovering most people read key words and assume they know what you were saying and having to reiterate or explain things, I am quite a lot lazier about what I say now :P If someone decides I might possibly have something worth sharing or elaborating on and ask, I will.
Nice power delivery... will be even better with the boost corrections as you mentioned.
thanks for putting up the chart.
Cheers
Justin
Awesome!
Thanks Trent! Thats what I wanted to see!
does that set up use the ebay turbo? Does it have cams?
How would a HKS 3037 pro S .68 rear compare to this in regard to response and top end power?
Trent-
Does that owner built car have cams?
If not how much would a set of poncams affect this particular set-up in terms of response?
Its fairly identical to my what my set-up will be aside from poncams, standard/front facing plenum, Haltech. (possibility of ITB's)
Basis of the build will be a long motor from Darren Lewis, Lewis Engines.
Edited by RBceffy25
At the end of the day I don't think any other turbo kit will come close to this sort of response and power figures for a $1000 flat, delivered to my door incl. custom lines to suit RB25 and fittings and all gaskets required for install.
Looks like its off to ebay! :)
Also, can anyone tell me what size wastegate would be ideal for between 17-22 psi on this turbo? (T67 10cm)
50mm :)
Bit big maybe? probably better suited to running stock boost, which defeats the purpose of the whole exercise.
I think most people with similar sized turbo with similar boost levels seem to be running anything from 38mm to 44mm.
I was thinking 40mm?
Grab a 44mm tial, big enough but no too big, always best to err on the large side with these things imo
No worries.
So would you say then that the difference between 40mm-44mm, at these boost levels, would be negligible?
Cheers in advance for all the advice.
yeh i'd like to give one of these a go on my rb25 too.
but what manifold are you going to be using? you won't get it on the stock one without a spacer and its gonna be restricted up top....
a 6 boost would be nice but not at $1400!!! then at the other end you got the nasty china junk for $200 that won't last a week, is there any alternative for highmount manifolds around the $800 range?
I thought they were $1250 from Kyle(6boost)?
Regardless of price, I will be using 6boost low mount with 44mm external gate. same manifold in the photo from Trent. If you are not willing to fork out for a proper, high quality, tuned length
manifold then I suggest you use a second hand TRUST item with a Mitsubishi/trust style flanged turbo (you can still find full kits for RB engines w/ turbo, manifold, wastegate and dump pipe) or try to track down a HKS cast item. Your only other option would be a custom log or un-tuned high-mount manifold, which I would think would be in your price range. If your handy with a bit of welding, you could have a go at making one your self, using steam pipe bends from any gas fitting place. Anything else in your price range is simply not worth pissing on. Do it once, do it right I say. If i were you I would just save the extra and get the 6boost. The benefits far out weigh the cost.
Hope this helps!
I had a GT35r on my RB25 and found it to be really good, Fineline is another person on here that has as well.
We both made 500+hp atw out of them and mine was nice and progressive, I would have to search for a dyno sheet but.
What size turbine housing?
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 馃槈. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 馃槏.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 馃檹 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 馃槈. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 馃槏 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
