  • Replies 41
Posted Images
hey guys so today was a busy day.
I changed the coils over with a mates ones that were working sweet and the problem was still there.
I changed the AFM to another pink sticker one, problem still there.
I decided to take a look at the ECU and to my suprise it has an odd one for it, and remembered that when i brought the engine it was out of an auto car.. and the ECU they gave us came with that engine.. so im guessing the ECU is an auto one.
The numbers are: MEC-R730 B1 6521, Ive done a search but cant find anything about this ecu.
I got a proper r33 rb25det ecu and checked the numbers on it and they are for this car but now it wont idle! its turns over and then dies straight away, if i give it some gas it i can hold the revs myself then if i slowly take my foot of the accel it will sit there idling but will be searching then pretty much die.
I unplugged the AFM and it was the same.. so while it was seaching for idle i got the mrs to plug the AFM back in and it died straight away. Would this mean its the AFM?
ok so today i checked for error codes on the manual rb25det ecu, i got code 12, which is AFM so i replaced it with another one and now it will idle fine and run, but again it is cutting out on boost!! im running out of ideas here!
Can anyone else think of anything to try?
Edited by prawln
I had the same problem when I finished my conversion. It cut out exactly like in your posted videos. I changed the spark plugs, coils, afm and couldn't find anything wrong. So I lowered the boost and took it to a tuner. Got a nistune and havn't had any problems.
ok so have some good news.. got the car fixed and sorted.
The auto ecu was causing the car to not get above 5-5.5k rpm so replaced with a manual ecu and that fixed that problem.
i was still having the cutting out on boost issues though so today i took the pod filter off and put my hand over the AFM quickly to see if i could hear any leaks in the intercooler piping.. and to my surprise bingo herd a hissing sound. I located where the noise was coming from and found that the T bolt clamp was on tere tight but when we put the joiner on the intercooler pipe was in far enough and the T bolt clamp wasnt actully over the piping so was causing it to leak! When looking at it it looked like it was on perfect but apprently not
Took for a run on 5psi actuator and ran mint!! so put the 10psi actuator and also runs mint!!! so problem solved!
Just need to bring the timing back to 15 degrees from 20 degrees as its idleing rough!
Big thanks for everyones help and sorry for this being such a silly minor stupid thing!
  • 5 years later...
Ive got the same f**ken problem its had me stumped for months changed heaps of parts and everything an stull cant get it but i dont think i have an air leak i can easly stall the motor by putting my hand over the afm. has anyone got an answer for this cutting out on boost problem? Its driving me nuts
This post should be in the hall of fame for real!
Stalling the motor by blocking the afm is not an indication of anything. Good or bad.
Alright this is the common problem with basic mods really my only solution is bigger afm and a play around with an ecu. got my hands on a scanner
it's not 1996, buy yourself a proper ECU
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
