  • Replies 41
Posted Images
hey guys so today was a busy day.
I changed the coils over with a mates ones that were working sweet and the problem was still there.
I changed the AFM to another pink sticker one, problem still there.
I decided to take a look at the ECU and to my suprise it has an odd one for it, and remembered that when i brought the engine it was out of an auto car.. and the ECU they gave us came with that engine.. so im guessing the ECU is an auto one.
The numbers are: MEC-R730 B1 6521, Ive done a search but cant find anything about this ecu.
I got a proper r33 rb25det ecu and checked the numbers on it and they are for this car but now it wont idle! its turns over and then dies straight away, if i give it some gas it i can hold the revs myself then if i slowly take my foot of the accel it will sit there idling but will be searching then pretty much die.
I unplugged the AFM and it was the same.. so while it was seaching for idle i got the mrs to plug the AFM back in and it died straight away. Would this mean its the AFM?
ok so today i checked for error codes on the manual rb25det ecu, i got code 12, which is AFM so i replaced it with another one and now it will idle fine and run, but again it is cutting out on boost!! im running out of ideas here!
Can anyone else think of anything to try?
Edited by prawln
I had the same problem when I finished my conversion. It cut out exactly like in your posted videos. I changed the spark plugs, coils, afm and couldn't find anything wrong. So I lowered the boost and took it to a tuner. Got a nistune and havn't had any problems.
ok so have some good news.. got the car fixed and sorted.
The auto ecu was causing the car to not get above 5-5.5k rpm so replaced with a manual ecu and that fixed that problem.
i was still having the cutting out on boost issues though so today i took the pod filter off and put my hand over the AFM quickly to see if i could hear any leaks in the intercooler piping.. and to my surprise bingo herd a hissing sound. I located where the noise was coming from and found that the T bolt clamp was on tere tight but when we put the joiner on the intercooler pipe was in far enough and the T bolt clamp wasnt actully over the piping so was causing it to leak! When looking at it it looked like it was on perfect but apprently not
Took for a run on 5psi actuator and ran mint!! so put the 10psi actuator and also runs mint!!! so problem solved!
Just need to bring the timing back to 15 degrees from 20 degrees as its idleing rough!
Big thanks for everyones help and sorry for this being such a silly minor stupid thing!
  • 5 years later...
Ive got the same f**ken problem its had me stumped for months changed heaps of parts and everything an stull cant get it but i dont think i have an air leak i can easly stall the motor by putting my hand over the afm. has anyone got an answer for this cutting out on boost problem? Its driving me nuts
This post should be in the hall of fame for real!
Stalling the motor by blocking the afm is not an indication of anything. Good or bad.
Alright this is the common problem with basic mods really my only solution is bigger afm and a play around with an ecu. got my hands on a scanner
it's not 1996, buy yourself a proper ECU
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
    • No clips on this one like the other connector. Only that red tab that I can push slightly up.
    • For any loom connector that has an obvious release that resists pushing far enough to unclip, just spray some silicone lube into it. You might also benefit from using a bent screwdriver or small pick to push in the right place at the right angle.
    • Hey all, I went to try and fix my indicator not canceling, but I couldn't remove the clockspring cable under the column so I could twist that green thin. Anyone know how to remove this cable? I see this red tab but didn't have any luck. I was thinking of unscrewing it but wasn't sure if it would cause issues. I did notice for my indicator stalk, 2 out of 3 cables were plugged in but the last cable wouldn't fit in the stalk. I'm getting it's for fog lights. It was like this when I originally pulled it off.
