As stated, I have a 1996 s1 s14 200sx with an RB26DETT R32 GTR engine,
*Engine rebuilt from ground up before fitted,
*New... rings, bearings, gaskets and seals,
*Honed bores,
*Tomei sump baffle
*Engine only has about 1,500kms on it
*resprayed rockers as you can see,
*R34 GTR turbos,
*Front mount intercooler
*Ram pods, boxed enclosure
*Relocated collant bottle,
*relocated battery to boot
*battery kill
*alarm system
*sony stereo system
*R33 GTS-T gearbox, full synthetic oil,
*synthetic engine oil
*Nismo short shifter,
*very small racing steering wheel,
*racing seats,
*19" wheels,
*3" exhaust system,
*Full fibre motive body kit
*custom tail shaft
Vehicle has been stored for close to 10 years, no joke,
has only 23,000kms on the clock/ vehicle, im more than happy for
the potential buyer to do back ground checks with the rta, police etc..
to checks it authenticity. It runs a/c still, all modified to suite new engine,
power steering to suite as weel, all elctrics work perfectly as factory
originally a series 1996, genuine luxury spec 1 s14 but i like the s2 update,
so changed the bonnett, lights and gaurds, then resprayed in the silver as you can see.
This stage i have not much time to enjoy the vehicle so the consideration to sell.
Full engineers cerificate, Blueslipped of course then regoed a couple weeks ago,
vehicle had last rego in 2002 ending, was sprayed in 1999 or 2000 there abouts.
Drves very very well, running 14psi mostly, good tune, would suggest a dyno
to get even better.
Please not low balling offers or test pilots as im in 2 minds to sell, if the right buyer
and price come along then it will deffinately be considered. I have put alot of time and
cash into this project so i will not give it away, i will simply keep it.
serious offers and further info please feel free to email me at
[email protected]
im not on forums very much but will try to check from time to time,
I will consider offers of $22,000
post-29606-1283934410_thumb.jpgpost-29606-1283934462_thumb.jpg[attachmen
t=303805:22042010223.jpg]
Edited by luvsit
https://www.sau.com.au/forums/topic/336076-nissan-200sx-s14-gtr-engine/
  • 1 month later...
*Honed bores,
*Tomei sump baffle
*R34 GTR turbos,
*battery kill
*alarm system
*sony stereo system
*racing seats,
*19" wheels,
*3" exhaust system,
*custom tail shaft
to get even better.
[email protected]
I will consider offers of $19,500
price drop to $19,500. offers considered.
still no trades please
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
