ok since i dint get a reply in m y last thread ill start a new one ...
put my inttake plenum on went to start up the car wouldnt start tryed again and it started .so i took it for a drive round the block but as it hit boost it was cutting out .pulled in to my drive way was idleng rought .started it back up went down the street and wouldnt go past 3000rpm at all .blowing heaps off black smoke ..i cheked the aftermarket frp and the pressure was at 80psi!!! so baked that off and thene the car wouldnt start and it smelt really fuely..so i left it for a day started up run like shit thene wouldnt start again ...changed the tps and then it started and died again ...so i dunno also changed plugs cheked cooler for boost leak the fuel pump is near new also the tps wasent set spot on the first time we couldnt get the accurate reading from it so changed that and it started but now it wont any ideas sorry for the essay
https://www.sau.com.au/forums/topic/336100-rb20-runnin-mega-rich/
well what did you expect lol, its just going to run ridiculously rich I'm surprised it even idles, the ECU isn't a magician, it expects certain things to remain constant as it it injects fuel based on airflow temp and throttle position, if you go changing the base fuel pressure then the injectors are going to be injecting far more fuel at the same duty cycle.
why did you install it? standard ones are good for 300rwkw
Edited by Rolls
installed it to run thene it was gonna get tuned lol ...how dose flooding the motor damage or canmanite the oil??..it only ran for like 30seconds thene i turned it off mmmm
if you ran it for 30 secs it is probably fine but if you flood it so bad that theres literally pools of fuel in the cylinders it will drain down into the sump if you leave it overnight contaminating the oil.
Edited by Rolls
400rwkw even. :)
I did lol a little bit when i read factory ECU & FPR... :(
cheers mate will be changing the oil asap ! must say there more help on here than nissansilvia ....good to have blokes that actualy kno wots going on on here!
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
