hi all,
i was wondering other than otomoto where do you guys look for/source old jap wheels eg longchamps/other SSR?
is it just a matter of being patient and waiting for a set to come up in for sale? how do yu go about getting them direct from japan? [second hand].
cheers.
https://www.sau.com.au/forums/topic/336102-jap-wheels-dish/
AE86 website. I looked on there for a while and plenty came up but prices weren't cheap. I ended up with performance Superlites which I really do like and the cost me $1080.00 for 16 x 8 -4 offset rear and 0 offset on the front.
https://www.sau.com.au/forums/topic/336102-jap-wheels-dish/#findComment-5437361
I do like the look of them but had concerns on their weight. I wonder if their GTR lite model is safe to drive on the street. Has anyone had any experience with import monster?
https://www.sau.com.au/forums/topic/336102-jap-wheels-dish/#findComment-5437744
Superlights confirm to aus standards, and the GTR light isnt as light as you would think.
That said, they are a cheaper alternative to wantanbe wheels, and If you bash one, a brand newie is only $270 odd away.
I used to run them on my daily, no problems at all.
(only took them off to covert my car back to standard looking specs)
As with buying wheels off ae86 forums, prices there reflect what they are worth in japan, combine that with that most wheels having been discontinued 20 odd years ago, and the poor exchange rate at the moment, stuff gets expensive fast.
I have a yahoo auctions account, If your keen,pm me and I can run you through whats involved and get some qoutes.
https://www.sau.com.au/forums/topic/336102-jap-wheels-dish/#findComment-5438296
thanks for the offer mate, at this stage i will browse ae86 and see how i go. if no luck i might get onto re the yahoo account.
https://www.sau.com.au/forums/topic/336102-jap-wheels-dish/#findComment-5445506
  • 6 months later...
sorry to revive an old thread.
ae86dc usually has alot of wheels to suit our old datsuns but as already mentioned they can be quite pricey and go quickly.
another option is to search yahoo auctions japan.
- go to the import monster site, and use their yahoo auctions search (import monster site translates it into japlish for you).
- once youve found the wheels you like order them through jesse streeter (www.jessestreeter.com)
- tell him how much you want to bid on the item for, if won he will package up everything and send them over to you from japan via seamail (6-9 weeks but very cheap) or ems (4-6 days very exp for large items).
- his commissions are very low compared to other sites which offer this service eg. import monster, nengun etc.
- very good to deal with, great communication and packages up the items very well.
ive ordered various parts for my 240z from him ,eg. rims, body parts etc.
https://www.sau.com.au/forums/topic/336102-jap-wheels-dish/#findComment-5746240
There is one place that has TONNES of JDM rims, in Parramattaa.
Otomoto
http://otomoto.shop033.com/c/4073478/1/used-wheels.html
Ben is a great guy to deal with, has been on the scene for YEARS, really knows his stuff.
The rare/big dish type rims normally sell pretty quick, even before they arrive in the country, so check the web-page regularly...
https://www.sau.com.au/forums/topic/336102-jap-wheels-dish/#findComment-5747882
    • FD RX7 I would probably marry if legal R32 GTR is toughest NSX looks like it's made from leftover Prelude and Accord bits
    • When going to a suspension shop should I send them the default nissan settings or just let them do their own thing? I ask this because I have aftermarket rear camber arms (front end is basically stock after I change to those nismo bushes)
    • Ok sounds good, thanks for your help. Hopefully if I end up changing it to the nismo bushes I don't get that veering issue. I don't think there's a point in lubing up these bushes again. Weird that it it makes just as much noise with all the grease inside it versus without grease prior to removal. Bizarre.
    • Yeah, you don't need camber bushes on stock arms to make a car drive straight unless it's got another problem. F'rigsample, slide the thing into a kerb, bend the front subframe mounts a little....subframe is now twisted, shifted or otherwise in the wrong spot...and you need to do funky stuff with the wheel alignment to get it to drive straight. Maybe a little more caster on one side, or a little more camber. FWIW, I can have my camber off side to side by a half a degree or more, and either way, so more one side, or more on the other, and the car doesn't really want to pull to one side. It will definitely ride road camber differently, and want to track uphill (ie, towards the centreline when on the LHS of a normal crowned piece of road, like it should) or want to roll downhill (which it really shouldn't). But on fairly flat road surfaces, like the middle of a 3 or 4 lane motorway, a half a degree either way doesn't make a lot of difference. I sometimes do quite a few miles with my wheel alignment messed up, because I don't always get a chance to set it right again after a serious dismantling, before I have to drive it to work again. Like, a whole week's worth of daily shuffle.
    • To clarify, I meant nismo bushes, not control arms (don't even think that's a thing for my car). So the suspension specialist said, if I buy those nismo bushes which are perfectly centered it will cause my car to veer in one direction. Whereas he said the current offset bushes that I have were put in on purpose to fix that issue. This will be my third wheel alignment if I put these bushes in lol. My chassis is straight, all my rails are clean.
