Conversion - Rb20 Silvia To Rb26
want_33
 Share
So this is my silvia, its in build ups section aswell. Have thought alot about building a head for it, a new inlet manifold and winding some more boost into it to see what can be achieved. But with the level of supporting mods i allready have iv been tempted to convert. considering the same amount of work would be required between a 25 and a 26 conversion, in my opinion the cost being the only differance i would like to see what others opinions are, and also the best way to go around this conversion as well as what to keep and what to swap.
see below for a pic or two and the mods list, cheers guys :(
Also i have allready spoken to mark at godzilla motorsport and have a few ideas allready
1992 S13 Silvia, Orange with RB20DET conversion
Orange with a very faint Gold Pearl
RB20DET engine conversion
TRUST TD06H-25G Turbo kit/stainless manifold
46mm External gate with screamer
Trust Adjustable Cam Gears w/ Trust Timing Belt
RB25DET gearbox
OS GIKEN Twin Plate Clutch
KAAZ 2WAY LSD (very Fresh, even have receipts)
Z32 AFM
SARD Fuel Pressure Regulator
SARD 720cc injectors
CUSTOM Stainless Intercooler Piping
HKS Pod Filter
BOSCH 044 External Pump
External Surge Tank
ASE Polished header tank
TRUST 600x300x115 Front mount
APEXI Power FC + Hand Controller
GREDDY e-01 boost controller with LCD screen
KAKIMOTO cat back exhaust with Titanium look tip
5 Stud Hubs
R32 Skyline GTST 4 pots up front 2 pots up back
BREMBO front discs
PROJECT Mu Street Pads front
TEIN HE Drift Spec Coilovers
BRIDE ZIEG III low max seats
Matching BRIDE interior trim on doors, glove box, mats & gear boot
NARDI swede steering wheel
SAFETY 21 HALF CAGE
CUSCO strut braces front and back
CUSCO Sway bars front and back
HICAS Lock Bar
HID Head Lights
Apexi RSM
DEFI White Face Boost Gauge, Oil Temp, Oil Pressure, Water Temp
PIVOT Security Start Button
TRUST Gear Knob
Boot Mounted battery
Factory nismo AERO front bar
Volk/Rays Engineering TE37 Rims
18x8.5 +30 front
18x9.5 +40 rear
With 15mm bolt on spacers all round
GTR Style grill
NO A/c condenser and lines removed
makes just shy of 260kw on 18PSI.
excuse the partially unasembled engine bay photo
all the photos are in the build thread
http://www.skylinesaustralia.com/forums/Ag...amp;mode=linear
you know if it was me, just put a rb25 in there, then you can use everything (rb20 loom, pfc etc). Spend $1500 on a decent std rb25 and 330-350rwkw. Thats what id do if it were my car.
just sell the core rb20, is it built or std? looking at power its made im reckoning std with very mild tune. A good rb25 bottom end should last as good amount of time if tuned properly, we have a few customers making that sort of power with t67's on std rb25 (for about 3-4years)
That is an option, but honestly I'd rather go an aftermarket plenum, some cams and a fresh head and really lean on the 20...
Or go straight to a 26
This really is my dream car, and when I was 18 I was going to swap out the sr for a 26 but never got around to it. If it proves to be a too expensive option or the forseable future I will build on the 20 as mentioned. It's kind of expected that a 25 should make decent power, so I just don't see it as an exciting stand out thing. A 20 making big numbers is a big deal in my opinion, and the 26 I just the pinnacle of a tough car for me.
And this isn't going to be hard parked, lots of drift rounds next year and everything is allready organized to make sure Sydney powerbroker is going to be a big weekend!
I think what Trent is trying to tell you is that an RB25 will offer far better bang for buck than a 20 or a 26 , cannot overstate too much what you get out of the extra 500cc's/larger ports/larger valves than a 20 has .
In loose terms an RB25 is a more budget minded RB26 , same sized bores , same sized valves and the major differences are what bolts onto the head .
An RB25 will make the sort of power easily that a mega expensive RB20 can only dream about and not cost an arm and a leg .
Personally if you plan to build something up , RB30 short and a 25 or 26 head .
Your call .
Your call .
yeah, a 26 is gonna be a big investment and honestly a rb25 will make 95% of the peak of a similar tuned 26.
if you go 25 all your "hot" side will bolt on (turbo gate etc...) you could do a forward facing plenum and use all the rb20 fueling system you have.
i love rb20's but a turbo like yours will love an extra 500cc.
not into stroking, and i wil never run a 30 bottom end. personal pref the end.
all good and well people suggesting i dont see were trent is coming from, and i honestly respect his decision as i know he is guru in the industry. BUT, i dont want a 25, i dont think you all understand why im saying that and why i want to choose between a 20 or a 26.
25's are expected to make good power, its just not a new thing, its been done over and over and im just not interested.
Thinking back to the days of the IMKAOS r32 that made big big numbers from a rb20 inspire me to follow the same path, i know he eventually went a 30/25 but thats not the point. when he made numbers in the 20 people's ears picked up. and he was noticed.
now for the 26, its just f**king tuff, plain and simple. "you have a gtr motor in there? get farked!"
seriously everytime a 25 is mentioned in here the thread is going off topic, so please keep to my two listed options? lean on the 20 with some fresh mods, or what would be reiquired etc for the 26 conversion.
thankyou
Off topic: Does anyone know what gearbox crossmember to use for rb26 with rb25 box in a s13????
I would go a 26 they are definately geting cheaper these days. It all comes down to budget, whether you want to keep the car or sell it and really just personal preference. You can keep a bit off the stuff you already got too. There is just something about the howl of a 26 at high revs for me :)
Edited by Goodfellas
want 33- go 25, you already have everything to bolt onto it.
most ppl go the 26 for the wank factor and remember there 2 turbo's = twice the problem
the only thing the 26 is good for is the solid lifters and thats only if you are going to run big cams
i have a 25 setup in my sil80 and i wouldn't swap it for a 26.
i know where your coming from but how deep are your pockets and all for "you have a gtr motor in there? get farked!"
you can always put 26 covers on your 20 :)
goodfella's- use r33 x-member with 2 tabs welded onto it that will line up with factory bolt holes
just wind the boost up on the setup you have now, if done right it will last long enough for you to make a decision worthy of keeping the 20 or upgrading, the 20 should give good service at 20-24psi if tuned well.
  • 3 weeks later...
I think even though more people might notice the 20 it will suck to drive with any decent amount of power due to the lag. I'd definitely go the 25 but being as you have ruled it because it isn't different enough (personally I think this is retarded, there is a reason everyone uses it, it works great and is cheap) so if the 25 didn't exist I would go the 26.
same thing so hardly.
Personally I think rb20s sound MUCH better than rb25s or 26s, much tougher note and less raspy.
Hell yeah the sound of a Rb20 at high revv's is unreal, any 1 remember the vid of the 80's race skyline RB20 NA screaming at like 8000rpm....
so ive decided that im going to build onto the 20 for now. looking for a spare head to build up. Going to give it a full birthday, swap my cam gears over to it. some 272 cams and anything else i can find off the shelf to fit it. otherwise everything else will be brande new from nissan aswell as a custom inlet plenum. Going to run bellmouths and possibly an aftermarket TB. So what headgaskets are people finding reliable on 20's these days? and who is running aftermarket head studs? should i warrant them?
And trent, who would you recomend in the sydney / newcastle area to tune a 20? your just a bit far out of reach for me to travel to
cheers everyone
 Share
    • Great write up. I was thinking abt getting the niftycity for my g37 the aliexpress links u shared r not working anymore. Can u share again please?
    • Good turnout and some old faces.
    • Wow its been a while since Ive signed in for sure.  Time gets away... Good question. So much was different between the two designs.  The RB315 was a test to see if I could do it.  Limitations were for the most part due to local machining capability.  Tolerances were an issue.  The 3.15 used a single OD dry sleeve, and was almost the same as a kakimoto spacer plate engine, except I used a plate design similar to the OS Giken plate.  I did not make the top flanges thick enough either.  I can't be sure if it was machining tolerances, or thermal distortion of the sleeves, but the engine did produce quite a bit of blow by.  The modified 87mm RB30 crank was also an issue, and was no where near as nicely balanced as the forged 90mm crank in the 3.4. The 34 was a next level build.  The sleeves were stepped for max thickness, and were a semi-wet design breaking though into coolant completely in the block.  Minimum thickness was 3.75mm and max was 5mm with the 90mm bore, and the new spacer plate also fully supported the tops of the sleeves closed deck style.  This combined with far superior CNC machining, and a cylinder hone finish that the machinist does on 3000hp pro stock cars resulted in no noticeable blow by at all.   In the end the 3.15 was removed to swap in the 3.4.  I discovered the modified RB30 crank had partially sheared the woodruff key on the balancer.  That was all that was wrong with it, but it did make the engine a paperweight at that stage. $1100 to make another crank for an engine with blow by issues was not worth it, considering I'd started playing with all Nitto forged internals instead. I hope you found this interesting.   Cheers, Ian
    • All their parts, when order directly off them are made to order. So you're able to customise fitment of things or delete things. E.g. I asked for no throttle cable bracket, no IACV port, etc. on my plenum. In hindsight, I should have asked for an IAT port/fitting welded on, hindsight no. Should have bought a M2 or 3 lol.
