Hi there,
I recently imported an 89 R32 GTR.
Its fitted with N1 turbos but was only running 6.5psi boost using the standard boost controller, I removed the restrictor in the vacuum hose and now the boost is up to 9psi. This seems low considering most posts etc seem to think that without the restricter it should run 15psi.
I have checked and rechecked all the piping etc looking for any leaks or splits but cant find anything.
Anyone have any ideas as to why its low? Could it be because it has the different turbos and as to how I can remedy it?
Thanks!
https://www.sau.com.au/forums/topic/336126-low-boost/
Hi there,
Thanks!
That's an easy fix. Install a boost controller
https://www.sau.com.au/forums/topic/336126-low-boost/#findComment-5437498
Not a faulty boost gauge have checked there as well.
I tried blocking off both lines going to the wastegates as a test, still the same, I thought that in theory that would mean they dont open so would max out turbos? Or have I got it horribly wrong?
https://www.sau.com.au/forums/topic/336126-low-boost/#findComment-5437739
AFAIK if there's no boost getting to the actuators then yeah boost should keep climbing unless the exhaust pressure on the wastegate flap is enough to overcome the spring in the actuator. If its only getting to 9psi then replace the actuators or tighten them up if they happen to be adjustables.
As an additional check some also fix the wastegates shut (maybe clamps on the actuator rods??) then VERY CAREFULLY run it up to verify it will go past 9psi. Again, the boost should just keep climbing so make sure you back off once its past 9 psi so you dont break something expensive....
Summary - 9psi with disconnected actuator boost signal then more than 9 psi with wastegates fixed shut = stuffed wastegate actuators. Someone will correct me if i'm wrong.....
https://www.sau.com.au/forums/topic/336126-low-boost/#findComment-5438506
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
