Just looking for any suggestions about my rims.. they are a bit gutter rashed from the previous owner and bits of the clear coat have started to peel off.
I was thinking either fixing them up and leaving them as per the pic but a mate said leave the dish polished and paint the 'ninja death star' parts glossy black.
I wouldn't mind new rims but the wallet disagrees at the moment.
Suggestions?
https://www.sau.com.au/forums/topic/336129-change-of-rims/
get them fixed up gutter rash removed, sandblast and powdercoat in silver...
but are they worth it... keep in mind you have to pay for removal of tyres from rims, take em to a wheel repairer, then onto a powdercoater then back to the tyre place to get the old tyres put back on... Im guessing $500
https://www.sau.com.au/forums/topic/336129-change-of-rims/#findComment-5437440
$700 for rims AND rubber? I fear I might disagree with your opinion of "nice" if that's the case :thumbsup:
If your on a budget, grab some spray paint and DIY. That way you save some money for some proper jap wheels in the future
lol nah i meant $600-$700 to fix rims.. rims that i want to buy are closer to the 2grand mark but with a discount i can get them for around 1700 with rubber.. Thats the dilemma.. fix my rims + paint + then replace rubber in a few months or buy brand new set of rims with rubber..
https://www.sau.com.au/forums/topic/336129-change-of-rims/#findComment-5438451
He said ANOTHER $700 which means $1400 all up for another rims and rubber. Anyway for cheap fix, just powdercoat them if you like the rims.
If you're thinking in that direction and wallet allows, get the rims and rubber then. Most people I know change their rim when rubber is almost bald anyway. Unless you really like the rims.
https://www.sau.com.au/forums/topic/336129-change-of-rims/#findComment-5438454
what are the rims that your looking at replacing them with? got pics?
i reckon the ones you got on the car look awesome, get them fixed. why spend another 700 bucks for shits and giggles, put that money to other upgrades?
https://www.sau.com.au/forums/topic/336129-change-of-rims/#findComment-5440276
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
