Finished tuning the little old RB20 last night using 50% CSR E85 and 50% BP98 mix (to make a E42.5) and was very surprised by the torque... Power was just under what I was hoping for but still very plenty for chirping 3rd.
Car mods as follows
K&N Filter
Z32 Afm
China cooler and piping
Deatschwerks 750cc injectors
Motor dead stock
Hypergear ATR43G3 0.63 internal gate on standard manifold
Full 3" exhaust
Walbro 255L/hr pump
Running 22psi on the E42.5
399.5hp or 298kw and 523.1Nm
BP98 curve vs E42.5 curve
Edited by SimonR32
  • Like 1
https://www.sau.com.au/forums/topic/336145-rb20-torque-monster/
Very nice :D And fairly consistent with one I tuned late last year, "unknown" T3/T4 on stock manifolds and a GTSLink running GTR Injectors and a Walbro fuel pump on 20psi, using E33 fuel.
Do you have a boost curve? Looks like a real interesting shape "curve".
I can get one pretty easily... It ramps hard hits about 24psi then drops back off to a dead flat 22psi till redline!
Hits a brick wall at that power, thus the flat top end of the curve
Ah yep, thought that might be the case (hitting 24 and dropping back) - was going to ask, as the one we did sortof hit around 17psi and crept up to 20psi... hence having a bit more of a peaky looking curve. We were working with a 2.5bar MAP sensor so 20psi was about the highest we felt safe going to, still makes for a hell of a quick car though :D
Its got the correction setup to flywheel..... its all flywheel measurements.... not wheel measurements
ooh and the correction is set to SAE which is an older measurement (gives about 5-8% inflation) switch it across to SAE 2004 (latest rating)
Will only actually be flywheel if they have something in the TCF field, the result I posted was axle power and I'd imagine if we had a 40%+ blend and were running 22psi we'd be at least as high as he was making. We had absolutely no hint of running out of flow and had a bit less lag, which is interesting as we were running a fairly quick run rate too.
Without any correction it was 393hp so more like 1.5%
Paint code: customgreen2010specbybbk
Hehe nice - sorry just trying to work out what to paint mine - me likey - you've pretty much nailed the dark green I had in my head.
What sort of max duty are the 750 injectors running at with the ethanol blend?
Wow that's laggy for an RB25 making 300rwkw. :\ An RB25 making 300rwkw should have way more than 2500rpm of usable torque!
Its not the most responsive turbo. Well compare to a GT3076 .82 with same boost. I think its not too bad. Unless if you run E85 and cam gears. There is nothing installed on it that can advance the turbo's response or power output.
Sigh... Thats not really a useful comparison. You can clearly see the GT3076 setup has notable issues.
Is there any surge on it Simon? Looks like its building and then just tapers a tad early on the climb up.
Something my 600hp GT30 did, it wasn't really audible eithe which didnt help to workout
Are you talking about between 5000-5250?!?
