Ok, its on! Have done an exchange with a friend for some parts which means amongst other things i now have some new SARD 700cc injectors. So they can go in with my new fuel rail with full ptfe/braid lines and fuel reg and we can start to see what sort of boost we can screw into my thing with E85 :/
Its on ... IS ON LIKE KING KONG!!!!
Must be in the tune. My thing does not hit that hard and sure as hell doesnt break into wheelspin, a little bit in st but 2nd gear just hooks up :(
I like the 20 in the corners as it has less torqe to turn the tyres and easier to get on the loud pedal. By corners i mean corners, not silly 120 deg turns on a skid pan, but 70km/h+ corners on a circuit
Mine does not wheel spin like that, but slow corners like on a skidpan it does not exactly shine in the response department, like I said need moar ballz :)
Mine comes on like a freight train... You really do feel the difference between 100hp at 4000 and 370hp at 5100 :)
Burst into wheelspin in 2nd and sometimes 3rd. Mind you mine is running a bit more boost than both your TD06 setups!
Also shit tyres do not help :( Going to try a set of KU36's after I fix the gearbox
Ok, its on! Have done an exchange with a friend for some parts which means amongst other things i now have some new SARD 700cc injectors. So they can go in with my new fuel rail with full ptfe/braid lines and fuel reg and we can start to see what sort of boost we can screw into my thing with E85 :(
that's what I thought when i retuned for manildra e85 last time but I hit the point of deminishing return @ 323rwkw... and killed the tune there, as it' pointless screwing in more boost past that point... my poor lil turbo just couldn't flow any more... :)
you got a dyno graph of your current setup handy roy?
do it... i'm loving mine for the price!
RE001 on the street, yet to decide on track tyres (I have not had enough days out on the track with this turbo to justify RE55's). Personally I am thinking Toyo R888's. But I want a set of rims just for the track, just hard to find decent 17's in 4 stud with width and offset.
that's what I thought when i retuned for manildra e85 last time but I hit the point of deminishing return @ 323rwkw... and killed the tune there, as it' pointless screwing in more boost past that point... my poor lil turbo just couldn't flow any more... :(
We found the same thing... We added both timing and boost at that power level and neither made any extra power!
Dont waste your time of money with R888s. Federal 595RSR id you can front $400 a tyre, or just the cheaper Federal or Khumos otherwise
The most responsive curve was the Greddy manifold and 100RON. The laggier curves are the 6boost manifold with 90RON and then the same with some ignition wound out of it
Most responsive curve was with 100RON fuel...Isnt that obvious?
I seriously hope youre not suggesting the difference in curves was a result of the manifolds?...Is that what youre suggesting?
HUGE difference between 90 and 100 RON fuel.....
the 90 is probably a typo which should say 98
Typo 98 vs 100RON. And i cant remember what rims and tyres my car had on it last time it was dynoed so since the curves are pretty similar just offset, perhaps there was a diam difference which meant the difference in response and curve. But having driven the car a bit with the new setup, I still think the 6boost setup if anything gives away a tad performance compared to the Greddy manifold, there is absolutely no way as far as i can figure that anyone can say the 6boost works better then the Greddy manifold for my setup. I just hope that the thing is a reliable beast of a thing and I get years of serves from it :P
Edited by Roy
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
    • I'm pretty sure if it's considered a gasoline powered vehicle you have to do certification against a fixed, very expensive certification fuel.  If you add two precats and then replace the main cat with two cats back to back you can get an RB26 to do 0.24 g/mi HC, 1.6 g/mi CO, and 0.3 g/mi NOx on the FTP-75 drive cycle. Found this out courtesy of California's laws at great expense. Divide by 1.61 to get g/km. So even with extra cats + precats you're blowing past the NOx limit by probably 2.3x. Probably the only way to get an RB25 or RB26 to meet euro 4 purely from an emissions per km standpoint and not durability/OBD2 requirements is retrofit at least intake side VVT, clearance the pistons to allow the full 50 degrees of advance so part throttle EGR can be maximized, and change the wastegate control from conventional 7 psi spring for example to one that is always fully open if the wastegate line is at 1 atm or higher and only close it in response to vacuum. See BMW's N54 engine as a reference for how this works. You would need to find space for a vacuum tank to function as an accumulator in this system. That way you can avoid any heat loss to the turbine as much as possible during cold start to heat the catalyst faster. Then find some way to eliminate as much as possible cold start enrichment to light off the catalyst rapidly. Maybe secondary air injection if there's no way to avoid cold start enrichment. Close coupled catalysts in the downpipe are probably necessary. I would also probably swap to EV14s, pick something with the correct spray targeting + dual cone pattern for the intake manifold you're using. EV1 style injectors to pass anything resembling modern emissions requires a very annoying air assisted injector system to break up the droplets at part throttle/idle which still doesn't work that great compared to just having smaller droplets from the injector to begin with. Realistically, you're probably going to be financially ahead if you just pay the fines instead. Or don't drive it into the city center. There's a reason why Nissan never bothered to even attempt certifying an RB for CA/US emissions. The VG30 needed external EGR on top of NVCS to pass in the 90s. Doing all of this work is also distinctly expensive and you're going to struggle to find anyone who is remotely interested in helping.
    • I remember those, people use to steal them to make bongs.....
    • IIRC, it only cost me a couple of hundred dollars to get an Liverpool Exhaust to fabricate a custom stainless resonator for me to fit in the available realestate that I had under the car I actually watched as they did it, took about 1 hour to cut up the material, tig weld the body of it, and then add it to the exhaust  4"in and out, with a packed 5" body, that was about 12" long In the end, it is some blindly simple sheet metal work for an exhaust shop, and some welding
