Leigh,
You and Andrew probably have the OEM boost restricter removed, which inside the hose that goes to the Boost Solenoid.
Once removed you can run a "Safe" factory boost increase, as what I have heard and read about so far.
  • Replies 58
i hope r34 gtr turbos can run a bit more boost safer than the r33 and r32 gtr's because mine usually runs over 1bar, the highest it got to was 1.18 on the screen which was right on the edge of the screen, maximum it reads is 2.0. in psi i think its roughly 16-17psi.
Not really - they are just newer, doesnt mean they wont/cant fail in the same fashion especially considering you dont know what was going on before you got it.
too much heat = bye bye turbo.
could happen to near new turbos IMO
I know everyone will say that it is way to much boost but I have never seen an R34 including mine run less boost than that. I bought mine with only a cat back and am in fact now running less boost with the computer and full exhaust. Factory mine ran the same and I know of a few other guys telling me the same, when mine was stock it used to hit 1.18 bar as well on occasion. Now with the wolf I have managed to run a perfectly steady .9 bar.
So done stress, the R34's just run more boost than the R33 and R34. In fact it may just be coincidence for me but I have never seen a 34 do anything but run minimum 1 bar.
yeah agreed, just need to save a little bit more and ill have enough for some new turbos :thumbsup:
ok thats good to hear that its not just mine then.
Geoff brought snowys old factory turbos - i think he got like 1,000kms out of them or something before they let go and took his motor with them (this is going back a few years now)
So they can indeed fail... It's just that most R34 GTR owners dont run them that high, for that long.
I think we will see more examples as time goes on of this occuring.
well it makes sence they are getting old and nothing lasts forever.
+1. How long do you run that 1bar? If you're just driving on the street it wouldnt be that long would it? If you're doing mountain runs/track, the risk just increases. Its all about whether or not you wanna take the risk.
Nobody really say you cannot run 1bar but rather its not advisable to run 1 bar because the risk or probability of the turbo blowing up increases.
Mine runs 1-1.2 bar factory with no dramas but I need a tune.
Mate you've got a NUR (according to your profile/nick). They have N1 spec turbos like mine so you're not comparing apples with apple. I'm running mine at 1.15bar with no dramas too... -.-;
with my BNR34:
Mods
-full exhaust system
-cam gears
-power fc
-kn panel filter
everything else standard, 1st dyno tune from Race Pace 280awkw (30,000km) 4 years ago. Now with (120,000km) dyno tune from Race Pace it's now 250awkw.
Not to sound rude but how did Racepace dyno your car all wheel? They only have a rear wheel dyno...so they can only generate numbers with rwkw...did they ever have a 4 wheel dyno before?..
aw/rw = same shit anyway.
Trent has a rwd dyno, and when i asked him about it he said he can put a "GTR setting" on or something which puts 5% more stress on it or something to act like a AWD dyno when doing GTRs, something along those lines anyway he can probably explain it more hehe
oops my bad, so how does he dyno it than? removes front drive shaft?
umm...yes...well thats what they did to mine when they dynoed it...they only have a rear wheel dyno...well atm they do...not sure if they had a 4 wheel one when you got yours...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
