Anymore than 10psi on a stock RB20 turbo, and the turbo will die. It's not about PSI either, it's about flow. A bigger turbo will outflow a smaller turbo at say 18psi. A RB20 can generally handle 200kw reliably, I generally don't see people pushing more than 250kw.
Wrong way to ask a question...its not really the amount of psi that will kill an engine...you can run 10psi which is really low and still hurt the engine if support systems are not up to scratch or the tune is off...
Look towards power figures more as a rough guide...a rb20det will happily live making 250rwkw all day every day if all is well around it...start getting to the higher reaches of 200 like around the 280rwkw mark and you will head into slightly more dangerous ground...that said...plenty or rb20s nowadays are making power in that region and still surviving nicely...and they cop a beating on a regular basis too...
I sexed up my fully stock RB20DET with S1 RB25DET Turbo with 16PSI all day, loved it
only mods were oil cooler, fuel pump, fmic, coil packs, ra ra ra usual bs, ecu remap
It is all about flow and the tune not the psi. Pressure is just a measure of restriction, if you get your head flowed, bigger cams, larger exhaust side of the turbo and larger intake then your psi will drop but you are pushing just as much if not more air. Also you could tune a motor running 6psi so badly that it will cook itself if you try.
A better measure of is how much power the engine can make before it goes bang, assuming a perfect tune. I've seen a few 250kw+ rb20s on here last more than a few years but it all comes down to many factors.
If you are making 220kw with a safe tune with maybe 15-20psi I don't see why you couldn't get a lot of life out of it
I want sumthing that's going to cum on boost around the same rpm as a standed rb20det turbo but a turbo that will Handel say 15 - 18 psi
This is a flawed question, you should be asking what turbo for x rwkw with similar to standard response. PSI doesn't mean anything unless you specify the turbo combination. As 15psi on a small turbo will flow similar power to 8psi on a much larger turbo.
Your best bet is a steel wheeled highflowed rb20/rb25 turbo that aren't too much bigger. The lowest HP rating highflow turbos are probably your cheapest option, otherwise a 2530 etc.
These will all make 200-230kw on roughly 16psi+ although you won't have standard response, it will definitely be laggier. If you want standard response I would recommend an rb25 turbo, these can push 180-190kw with a good tune and 12psi, will only increase the lag by about 500rpm.
Edited by Rolls
  • Like 1
I've seen standard CA18's run 56psi and 100+ dyno runs. Standard head gasket, standard NA pistons etc etc.
I didn't believe it when I heard but then I saw it with my own eyes.
What these guys are all telling you is true. You are probably asking the wrong question.
If you want a turbo that can run 18psi and have almost factory response then you need a highflow or a GT2860RS
  • Like 1
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
