Hey guys i'm getting some cheap Gtr rb26dett Injectors with custom fuel rail & i'm planing on using them on my s2 rb25det.
So the question is will the gtr injectors fit to my rb25 injector loom?
& i've also been told the resistance is different between the 26 & 25 injectors? What would i have change/setup to run these 26 injectors with my stock ecu? (& yes i plan on getting the ecu retuned after this mod is done)
any help would be great :thumbsup:
cheers luke
https://www.sau.com.au/forums/topic/336205-gtr-rb26dett-injectors-into-rb25det/
how cheap? i reckon get some highflow stockers cheap and then all you need is retune
got them with a plenum i brought just waiting on them to turn up in the post. but i've head all sorts of story's on installing them into the rb25 so sticking with the gtr ones as they come with a custom fuel rail also
RB26 ECUs run low impedance injectors with a resistor pack (like: http://justjap.com/store/product.php?produ...at=0&page=1 ). Whereas RB25 injectors are high impedance type, RB25 ecus expect high imp injectors.
so i should get my hands on the rb26 gtr injector loom & the resistor pack & the injectors will work fine with the rb25det ecu right? thanx
  • 2 years later...
You guys do realise (?) that you can't just run different injectors on an RB25 ECU, because in the first instance, if you do no tuning, the mixtures will be all wrong, and in the second instance, you can't tune the 25 ECU easily. You have to change ECU to change injectors.
I should have been more specific, i have a RB20 Nistune ECU that can run RB26 injectors so long as a resistor pack (which i have) is wired in. It can also run a RB25DET..
Is there any physical difference injector to injector, i've read that they are a tight fit in the side feed rail but apart from that?
Top feed rails can be fitted to RB25's.. would this work with 26 injectors?
Ta!
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
