hey guys got a crashed r33 im parting out
the drivers door an rear quarter is stuffed major almost everything else is good
has leather but drivers seat torn all trims have leather/retrimed - tan in color
motor an box are gone the rest of stuff is there
pm me for what you want an if your after the shell hit me up i need space
also have some 18's off it tires stuffed rims are ruff as
has pedders extreme coil overs have receipt for $1200
so hit me up will post small things
pickup from Wollongong for larger items or whole car
contact thru here or 0411241499
Edited by Ty$
https://www.sau.com.au/forums/topic/336209-striping-r33-wollongong-nsw/
PM ME WITH UR OFFER FOR WHAT PART!!
interior should b sold tonight still have alot of good stuff left
motor
diff
gearbox
brakes
hubs
all gone
panels remaining - headlights coilovers exhaust full 3" 18"rims
post prices of items or this will be locked. forum rules are clear and simple
glass $50 each come remove your self
rear bar $100
front bar $100 sum small damage
coilovers $750 pedders extreme
18" roh gold/chrome rims $350 bald tyres
boot $175 with wing
fuel tank $70
boot trims $30
2x stockies $75
guards $75ea
mirrors $50ea
full 3" exhaust $275 - offer
headlights $100ea
taillights $100ea
grill $45
bonnet $200
heater/aircon control $40
heater $120
entire floor carpet $100
roof lining $60
center roof light $20
map lights $20
holy shit handles on roof $10
lhs a pillar $20
speedo cluster $100
glovebox $40
all seatbelts $40
rhs sun visor $20
drivers door with electrics $50
passengers door slight scrape $100 with electrics
bonnet latch $35
horn $15
rear skyline strip between lights $60
scuff panels inside doors $25 pair
fuel cap covering panel $20
windscreen wiper stalk $15
indicator stalk $15
steering column $30
many more parts pm me with wat ur after
