hi all, just wondering what gbox oil were running out there,
im getting a gtr box, the dude said it was starting to crunch occasionally 3rd to 4th at like 8000rmp... (dont ask :S)
ive heard good things about redline shockproof and royal purple.
with the redline would i want a heavy or light?
seems like 75w 90 is a common thickness.
thanx all :D
Edited by chef_stagea
https://www.sau.com.au/forums/topic/336278-gearbox-oils/
thanx all :D
if you're getting a gtr box and u know it has issues, then why not fix the problem rather than applying a band aid?
shockproof does root synchros. good for straight cut/dogboxes but BAD for gtr stock boxes
do yourself a favour - take the box to a trans workshop, get the synchros fixed and check out the gears for stress
-D
https://www.sau.com.au/forums/topic/336278-gearbox-oils/#findComment-5439919
I always have heard NOT to put shockproof in because it ruins syncros.
Im running Castrol Syntrax 75w90 in a RB25 box.
I've been told the same thing and read it on forums. I spoke to Shaun at Boostworx only yesterday (want to do both diff and gearbox) about this and he's assured me that this is what they use and recommend for gearboxes.
https://www.sau.com.au/forums/topic/336278-gearbox-oils/#findComment-5439987
I'd rather believe a pro, than forum 'experts'.
:cool:
https://www.sau.com.au/forums/topic/336278-gearbox-oils/#findComment-5440000
:cool:
Same. My mechanic however said the same thing as forum experts about the Shockproof (aka smurf poo) - said its notorious for wearing out synchros and then explained to me why
And considering how shagged my box is, I'm not surprised. Been using good quality mineral oil since and while I do have issues with the synchros, it hasnt gotten progressively worse
Even Redline themselves say on the website 'not to be used with synchromesh gearboxes'. so yeah. believe the company or believe the tuner? I know shaun knows his stuff but I personally would never use it
-D
https://www.sau.com.au/forums/topic/336278-gearbox-oils/#findComment-5440027
I have got redline shockproof lightweight after trying the castrol in my r33. It didnt fix the crunch from 1 to 2 but it did make it alot better. It only has a slight crunch every now and then
https://www.sau.com.au/forums/topic/336278-gearbox-oils/#findComment-5440114
After asking around about the shockproof stuff, sometimes it can be too thin, and feels like there is is no "resistance" in the gearbox, almost "too quick".
Ive got some Castrol Syntrans 75w-85 in my 20 box, feels nice.
https://www.sau.com.au/forums/topic/336278-gearbox-oils/#findComment-5440841
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
