SPLITFIRE COILPACKS NOW $550 DELIVERED
TAKATA RACING HARNESS NOW $550 DELIVERED
ALSO STILL FOR SALE
NISMO SHIFT KNOB PRICES ( AS IS )
APEXI POWER INTAKE (GTR33/34) (Price As Is )
SARD FUEL REGULATOR $170 Delivered
The splitfires are to suit a s1 or s2 r33 motor?
Edited by KDS_HR31
By the Splitfire web page it fits all GTR RB26 from
SF-DIS-001 fits these cars
Skyline - R33 GTS-t S1 - ECR33
Skyline - R32 GTR - BNR32
Skyline - R33 GTR - BCNR33 (from 95 onwards)
Skyline - R32 GTS-t - HCR32
SF-DIS-005 fits these
Skyline - R33 GTS-t S2 - ECR33
Skyline - R34 GTR - BNR34
  • 1 month later...
I'll update what's left tomorrow as not back home yet and been away in Japan .
There's definitely
Takata Harness
1 Set of Splitfires but can't remember if for 32/33 or for 34!
Apexi Power Flow Filter kit
Sard fuel regulator
And one of each of Nismo knobs but not sure what's 10mm thread and what's 12mm.
Like I've said, been away for over a good month not 100% exact sure but will post up everything left tomorrow.
OK whats left is as follows...
SPLITFIRE COILPACKS Set For GTR32/33 $550 DELIVERED
TAKATA RACING HARNESS $550 DELIVERED (this is original takata, not dodgy copy)
NISMO SHIFT KNOBS ( 1 of each left )
Nismo Duracon (Black) $65 delivered
Nismo GT500 Duracon $92 delivered
Nismo GT500 Titanium $180 delivered
APEXI POWER INTAKE KIT (GTR33/34) $390 delivered
SARD FUEL REGULATOR $165 Delivered
GTR NUMBER PLATES
33,34 and GTR Still available $60 Delivered
Sold
Jun Oil Pump
Grex Oil Relocator kit
Nismo Leather Shift Knob
Splitfire coilpacks for GTR34
GTR32 Number plate
Do you still have splitfire coil pack for rb25 gts
pm sent
hey mate can i get the gt500 titanium gear knob off you
pm sent
  • 1 month later...
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
    • Turbotapin   so I am about to be mounting mine up been waiting for the body to get finish at paint. I had a question. I was told our Speedo sensor it originally in the transmission but the cd009 is in the diff on the z. How did you get around this?
    • I definitely do recommend having a fab/grinding/dirty shed or area to keep all that grinding dust out of your main shed.  But you're right, it doesn't matter how much room you have you still end up filling it! I might even do a short video which will make it easier to fully take in the horrors of what I've created...
