As per title and description, Im not sure if this would work as the extra fuel used in E85 compared to 98 PULP.
Looking at keeping fuel RON higher for track days to try and keep it ?safer?.
I usually put in a octane booster.
I run 800 cc injectors, Bosch 044 in tank and a Link ECU.
I would run E85 on a safe E85 tune if there was more than 1 place where I could buy it in Sydney, but alas there isnt, and Im not that dedicated to get 44 gal drums of the juice.
Thanks, Mark
https://www.sau.com.au/forums/topic/336289-can-i-run-e85-on-a-98-pulp-tune/
mark if you have a Link G4, talk to yavus about getting a 2nd fuel map done for E85, that way you can switch between the two with a switch on the dash/in the glove box connected to the ECU (run the tank to empty and then fill with 85 and switch over the map)
  • Like 1
Yeah Unigroup is building me a new motor which should be finished soon so a switch between maps sounds the go when its getting retuned....
I must look into this further....until then octane booster is it then.
Happy Days
just set it up as flex fuel, the G4 should have no issues.
Surely for the flex fuel to work they need to do lost of dyno time varying the mixture to confirm the afrs are correct? Or do you mean essentially use one or the other.
Edited by Rolls
Link supports the seimens sensor, if a megasquirt can do it i reckon my calculator should be able to work it out :thumbsup:
i thought they only supported the Siemens sensor for that? its possible but not cheap.
you could also do it via a permanent wideband sensor, but sensor degradation over time would need to be monitored. A dead sensor would wreak havoc.
Using dual wideband sensors could work, but you are getting up there in cost. How much is the flex fuel sniffer sensor anyway?
It seems the sensor outputs a square wave of varying frequency. How many ecu's can take this type of input?
http://www.theturboforums.com/smf/index.ph...8727.msg1083049
Most Ecu's will work with a pull up resistor.
The sensor is not cheap but in the scheme of things $500 (max for new version, as old versions are unreliable) is not too bad for the convenience of filling up anywhere.
Im working with a ecu manufacturer at the moment to integrate the inbuilt diag so it will set off the engine light if it goes out of spec (same as in factory installs)
I will check that thread out now
http://e-85.com.au/e85-performance-fuel/
$500 is OK, Flex Fuel thingo sounds like its easy to install (not by me of course, I only fix things with hammers)
COMPATIBLE FUEL SYSTEM COMPONENTS: Because ethanol contains oxygen, it can form corrosive agents. Any water that enters the system can promote the formation of formic acid. Although this process takes a significant amount of time before damage occurs, the tank, pump, and lines should be either stainless steel or coated with a plastic material that is ethanol-compatible. All natural rubber parts that could be in contact with ethanol must also be replaced with synthetic and other materials.
From reading this they suggest a stainless/plastic fuel cell and replace all lines as well as it is corrosive, dont really want the rear of my boat looking like a A9X with a big arse stainless tank hanging low (though the extra volume of fuel would be welcome(suppose I could paint it black ?)), but meh, might ring around some places that fab tanks for a price.
More to follow.
Mark
:) Yeah OK Im a idiot, was reading in anouther thread about fuel pumps and it said if it was a GTR it would have a plastic tank, so I ass umed that a GTS-T wouldnt.
Thanks man.
:P
  • 2 years later...
Digging up an old thread here, but I pulled my fuel tank on the weekend to give it a full clean out (gunk + BP98) and to replace the fuel pump with a Walbro 460LPH unit. I have a PowerFC with a BP98 tune.
Given the car will run lean with the E85, but also given I'm keen not to introduce BP98 back into the tank, I'm wondering whether I can fill the tank with E85 and drive carefully (i.e. no boost, minimal revs) to the workshop to get tuned? I know it would clearly be safer to get it towed but that might be a hassle with work hours etc. Obviously I don't want to cause any damage so if there's any risk of that even off-boost then I'll just have to get it towed but just looking for some thoughts or experience.
Cheers
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
