Hey up for sale is my 1997 Toyota chaser tourer v factory manual (jzx100) it has a 2.5L vvt-i turbo engine with tasteful mods(120,000km). . Im asking $19,700 o.n.o
If youre looking for a neat, quick, reliable and smooth car then this is for you, had no problems at all With it runs great and looks great recently had the 100xxx major service done and new tyres on rear along with new brake pads all round and machined rotors so save some money its my loss and your gain. Car will not disappoint!
Extras:
. High flowed CT26 turbo (done at a.t.s 10,000km ago) (runs stock boost)
. Exedy HD clutch (done 10,000km ago)
. Front mount intercooler
. Tien flex fully adjustable coilovers
. All oils changed (1500km ago) (engine oil done every 4,000km)
. Custom dump pipe with 3" apexi exhaust system and cannon
. Speedy hp design wheels 18" by 7.5 wide with new tread
. Black tint, trd shifter
. Kenwood touch screed dvd/cd player with jbl sub and 4 6" speakers and 2 tweeters.
. Comes Factory with:
. torsion lsd diff
. Xenon lights
.Powermirrors
.Carboninserts
. Very clean interior and seats
.Xenon lights
.ABS
.4 airbags (2 side, 2 front)
All up its a nice car to drive and in mint condition, first to see will buy, please no time wasters feel free to ask me anything just txt or call me anytime on 0433440530
thanks.
img-resized.png Reduced 91%post-76328-1283481676_thumb.jpg 1600 x 1200 (308.27K)//img-resized.png Reduced 91%post-76328-1283481778_thumb.jpg 1600 x 1200 (380.78K)//img-resized.png Reduced 91%post-76328-1283481977_thumb.jpg
Edited by toddo28
recently done: brand new tyres on the front, near new on the rear(95%), new fuel filter, cleaned afm and 02 sensor and filter, cut n polished and waxed and fire extingisher in the boot :)
how does it compare with a 32/33 gtst? performance wise
Much much nicer for daily duties, 1jz's are so smooth and sweet sounding and with more torque on tap than a rb25 they are plenty quick.
if i compare it to my mates 32gtst would be harsh as yehh its practical fo eveything, handles like a dream, solid as braced chassie, shit loads of power low down touqe and quik as spool and the relibility of a toyota. honestly i could sit here all day talking up them but yeh its pretty much sex on wheels man
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
