Thought I'd look up some PS4 info when I came across this;
http://playstation4.net/playstation-3-finally-cracked-704
In summary,
In quite possibly the longest time it took hackers to crack anything, four years after its launch, the PlayStation 3 has finally been cracked. Best (if you’re into that sort of thing) or worst (if you’re Sony) of all, is that the crack is applied via a simple plug and play USB stick, complete with a GUI installer that doesn’t void warranties, is compatible with any region and model of the PS3 and claims to never brick the console. Other features include backing up games to an internal or external hard drive, which allows them to load faster, and the ability to install homebrew applications.
Oddly enough, the creators of the jailbreak are selling it for a price too exorbitant for something designed for piracy at $130.
https://www.sau.com.au/forums/topic/336317-playstation-3-finally-cracked/
  • Replies 50
Just don't play On-line with the USB Stick plugged in as Sony will ass f**king rape you then :cool:
True that. My idiot mate had played Resident Evil 5 on his 360 whilst online before the game was officially released. Ass raped nicely... well, just banned really lol
Considering a chip in a XBOX can cost you what. $80-$120 depending on what you want
Pricing seems reasonable. End of the day you are paying for a solution.
Just because someone isnt doing any actual physical mods means little - sounds like a solution that isn't going to get you banned so it attracts that price.
After reading it, I'm still not entirely sure how this works? The geek-speak doesn't go down too well in my mind I think! How are pirated games then used with the use of this USB type thing?
(Cracking the PS3 is to enable use of pirated games right?) :thumbsup:
So the pirated games will come on USB's? I remember when they first cracked the 360 they were doing something like this.. The people I used to buy pirated games off in Asia told me the 'pirates' didn't see how they could pirate games as they'd need to be on blu-ray discs and the prices wouldn't be all that much cheaper than originals?
This was years ago though when blu-ray was first appearing, guessing they've gotten a fair bit cheaper now? Or would there be a way around having to use blu-ray?
Couldn't sony make an update to stop it from working?
That's the problem. This mod is fundamentally the same as all the other mods; Sony will eventually bring out new firmware which will stop this one from working. Therefore introducing new hacks and so on.
The vicious cycle begins...
They already have, yesterday I had to update my PS3 and with some further reading on the internet found out the update only existed to block the use of this crack.
it rips the game to the hard drive or external hard drive so you dont need the disc, and if you look around on torrent sites ps3 games are popping up everywhere on demonoid and funfile, and theres a seller on ebay selling the teensy boards with usb cable for about $100 delivered as i have ordered one a few hours ago :-) there really easy to program/flash, but yes the only drawback is when sony does the firmware update you have to wait for new firmware for the teensy board.
And from a fair bit of searching when able to play online there has been no problems yet, but im sure sony will find a way to detect non original games soon enough.
It was also recommended not to update to newer sony firmware yet as there is loads of problems with it, but if playing online you have to which sucks.
so your saying you can play riped games online or not because whats the point in haveing a downloaded game if you cant play online ?? most games now are fmade for online play
Yes you can play online so far with ripped games, it's just when Sony releases their update you need to wait for the update for the USB board, otherwise you just have to play them not online...
I've got 80 games all bought when brand new, I think I deserve a lil something back. If you can get it for free why not, if you truly appreciate the game I would buy it. So yeah cheap I don't think so chief...
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
