f**ken scum pinched my stagea tonight round half 6pm
was clublocked,locked and nothing of value in sight thro the windows
it's green mainly,matte black 260rs rear bar,260rs black sideskirts,blackfront bar
big black rear wing.am performance straight pipes hanging out the back
work radbotes,chrome dish (good luck selling these f**kheads,there the only set in the country)
keep an eye out lads,will update this wen I hear back from the cops
it's been reported,so I'll just have to wait now...
Guess I'm buying a gtr abit sooner than I expected
worst thing is I've been collecting parts to convert it to manual for a couple months now
was all ready to go this Sunday....
Farken gayness
https://www.sau.com.au/forums/topic/336354-stagea-stolen-tonight-magill/
  • Replies 140
Thats farkin ghey. I was just reading the other stolen vehicle threads thinking that my stag should be safe cause it's volvo spec..... not the case obviously.
you Got insurance to cover it? i'll keep an eye out for any cheap random green stagea parts!!!
and I take it from your post it didn't have an alarm?
FOR f**kS SAKE PEOPLE, EVERY (and I mean EVERY) SKYLINE THAT HAS BEEN STOLEN RECENTLY HAD NO ALARM. Use your brains and put an alarm in your cars ffs. This is beyond ridiculous - how many have to go missing before you finally get it?
wasn't this car advertised for sale at some point? did ya have any suss characters checking it out? and if so, did they suss it at your place?
Edited by Big Fella
Car is fully comp insured,hopefully justcars are good about it
Car was booked in for an immobilized and alarm install tuesday
car was stolen from work,I'm a chef so whoever stole it knew I was working there and that I'd be busy at that time
the exhaust is blisteringly loud,although I stand under a commercial range hood all night and we were getting raped tonight and were super busy
there's no way in the word I'd have even heard an alarm go off anyways,thought the clublocked would be sufficient for the time being
and nightcrawler,there's no need to be a dick all your life
guys are having there cars flogged all over the shop and all your doing is kicking them while there down
even if my alarm was fitted today,I wouldn't have heard it from inside the kitchen
wait till someone steals something of yours that you have poured thousands of dollars into,a shitload heap of work
not a nice feeling mate
especially wen you have paperwork in the car with your current address blah blah
try having your car stolen,then being super worried and rushing home to make sure your wife and 8month old boy are ok
f**k the car,my families safety is more important
who knows whether these donkeys would go down the path of robbing my house too
Edited by -RBD2-
Thanks chuck
good to get some support instead of wankers ragging on you wen your down
hope the big green girl with the fat black arse turns up soon
Edited by -RBD2-
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
