Why pay big dollars for splitfires when you cant get yellowjackets for cheaper and they are a proven performer?
Contact Paul from performance wise in the trader section and he will sort you out. Nice bloke as well
Its not always the case.
When you are IN Australia its better, but when your not, its doesnt seem to be worth it. For some reason, your postage is heinously expensive. (to NZ) and i dare say a shit load more to Sweeden! I def would have gone YellowJacket if the shipping had'nt killed the cost benefit.
They are on special at Nengun at the moment. Dam good price.
Yellow's from the NZ distributer were going to cost $575NZD+ Local shipping, (approx $452AUD)
Nengun cost me $640NZD to my door. (approx $500AUD)
Sign up with them to get an accurate price. If your not logged in the prices appear to be a bit more.
Edited by gotRICE?
Try a trader on here its a bit closer to you
RSP ones are cheaper and just as good
http://www.skylineowners.com/forum/
I think you'll find Japan is a bit closer to Sweden than Australia is!
fpmsl
Did you actually click the link if so
you need to learn where country's are in the world mate
Skyline owners forum is in England
Here you go
http://www.skylineowners.com/forum/showthr...light=rsp+coils
Edited by jjskyline79
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
    • Good question, I don't really know tbh...I'm pretty stock thought, where could I check this?
    • This. I'm confused by the whole discussion. The only reason you would have a car with e85 only if it was track use and you only ever used e85. All other use cases you add a flex fuel sensor, do the flex tune (you only need to do a couple of % and then interpolate the rest) and then you put whatever the hell you feel like including a mix in the tank and it just works. Want a long drive? fill with 98 Want max zoom? fill with e85 Got a half tank of 98 then find e85 somewhere? Throw it in.
