I am keen to change my power steering fluid on my r33 gts-t s2 as it has gone a little off colour, now tending to be more brown than red.
Castrol recommend just their plain power steering fluid, the red stuff. is this ok for the skylines?
My next question is what is the best way to change it? Happy to flush it a few times if need be. It it easiest just to undo the hose from the bottom of the reseviour and refill then repeat a couple of times?
cheers
https://www.sau.com.au/forums/topic/336377-changine-power-steering-fluid/
i think there is a drain somewhere not sure.. but with mine i undid one end of one of the metal lines under the car so fluid didnt get all in the engine bay, then with engine running you can move the steering wheel side to side and it will push all the fluid out the line...Just do this till no more fluid comes out...
Do the bolt back up then put fluid in and move steering wheel side to side again with the cap off and you will see air bubble coming out of the reservoir, keep doin this till it stops making bubbles...
Beware, if you put too much fluid in it will overflow the reservoir cause when you move the wheel it pumps out,so just fill it up a bit move wheel, fill, move wheel, repeat till full and no more bubbles coming out...
Pretty sure any steering fluid will work and some auto trans oils as well and a litre bottle is heaps
Edited by Arthur T3
undoing the lines under the car is a bit of a pain.. i undid the return line at the reservoir and put it in a bucket and then kept the reservoir filled (not too full as it rises up when you turn) while i turned the wheel left and right by hand (car on axle stands, engine NOT running). you eventually start seeing new fluid come through, but the colour change is only slight so it can be hard to tell. reattach the lines and do several turns lock to lock to clear any air in the system.
then start the car and do several turns left to right, just in case there's any air in the pump section.
arthur's method probably works too and more economical with the fluid but i read someone who had done it this way so i copied it.
there's no drain line and nissan don't seem to list a service interval for PS fluid in their service manual. I did mine anyway because i don't like having old fluids in any of the systems. used the castrol power steering fluid.
use castrol trans max z this is the best stuff u can get and ur only probs going 2 do it once so go the good stuff and also think about replacing old hoses at the same time saves having to drain the system again
arthur's method is a little suss. coz... i heard you shouldnt run the power steering pump with no fluid, because it uses the fluid to lubricate itself, so running it dry might cause damage.
kinks' method seems more appropriate.
i was thinking of changing mine soon, coz my p/s fluid looks a little brown.
anyone have other methods of doing this?
Remove the return hose to the reservoir & run it into a bucket. Have a mate stand there blocking the hole in the reservoir. Start the car & get your mate to keep filling the reservoir with new fluid as the old stuff runs into the bucket. While this is happening you should be in the car turning steering wheel lock to lock. Continue until only clean oil runs into the bucket then turn off car, re-attach the return hose, fill, re-start car, bleed & repeat until fully bled & at correct fluid level.
This is a full flush & what you would do if system was contaminated (water, etc) however you will use quite a bit of fluid depending on how dirty the old oil was.
I had a bit of a accident that chopped the metal line under the car and had to get it home so i did the best I could to fix it with hose and clamps, that got me to the need of the block before it blew the hose. It wasnt a long drive so I drove it home and no harm is done...
Remember most oils do stick to moving parts. Running it dry for extended time will no doubt do damage but for less than a minute it is unlikely to damage anything..Power steering pump does rattle like a bitch though when its empty but soon as you hear it rattle shut it down
Also Undoing a line is as simple as undoing 1 bolt how is that a hassle? its more of a hassle to clean fluid from your engine bay...Either way is fine anyway i just did this cause i was changing the line at the time
Anyway thats how i did it and it worked fine, And for the record i did have it on stands just forgot to mention it But its not that important...
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
