i dont think that will help because it runs smooth on low boost, and misfires on high..
is it easy to do myself?
ok then, don't take my advice. :D
gapping your plugs should do the trick, but if not, then it may be your coils. Even though you ruled them out, try wrapping them in electrical tape so they don't earth on the head, sometimes the insulation wears out...
haha all good bro :)
For future reference, what's happening is the spark is too weak to jump across the gap in your plugs, and the higher boost level is 'blowing out' the spark, and misfiring. When you gap the plugs down the gap is smaller and the spark has a shorter distance to travel :)
Good luck dood.
haha all good bro :P
Good luck dood.
Not 100% correct. The spark is not ''too weak'' the fact is higher boost is causing the engine to rev quicker so air veloicity is alot quicker and will blow out a large spark (big gap eg. 1.1mm gap). So yes a smaller gap (and spark) is used on turbo cars becuase of this reason. :)
Cheers.
Not 100% correct. The spark is not ''too weak'' the fact is higher boost is causing the engine to rev quicker so air veloicity is alot quicker and will blow out a large spark (big gap eg. 1.1mm gap). So yes a smaller gap (and spark) is used on turbo cars becuase of this reason. :dry:
Cheers.
Isn't that exactly the same thing I said, just worded differently?
i.e. too much boost blows out the spark, cos the gap between the electrodes is too large, hence the spark is not intense enough to jump the gap before the air blows it out.
  • 3 weeks later...
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
    • with the car running (runs fine when temp is cold), I unplugged the MAF and the car stalled.  I have already cleaned it a week ago.  I unplugged the O2 sensor from the left side of the vehicle, and the car was still running.  I let it idle for about 5-7 minutes and shut it off, to see if it would restart, and it did not.  It cranks but doesn't start after engine temp gets up to normal range.   I still need to look at the coolant temp sensor, is this one at the top or bottom of the radiator? Or is it one of the sensor threaded into the T-stat housing?
