Parts from my parted out 33
Front brake calipers
Front slotted DBA rotors
Rear brake calipers
Rear rotors
Front and rear 5 stud hubs.
$600 ono for the lot, if you need anything else for a 5 stud conversion it will be included aswell.
will sell separate if I have no interest in the lot.
Make an offer as I want this stuff gone.
Rear brake calipers
Rear rotors
i have an 1996 r33 gts N/A series 2..but mine are a 4 stud is this everything i need to make the conversion? and this will fit on yeah?
Edited by Shannond
I should have everything mate but Im not sure exactly what is needed, If you find out what is needed I will make sure it comes with it.
If you organise frieght I can drop it off to a depot, I work near a TnT, Startrack express etc
Edited by TJ_R33
Rear brake calipers
Rear rotors
Are the front discs 296mm or larger?
...as they'd be going an S15 - i'd be looking for a meaningful increase over 280mm.
Also, would the sale include the BMC, cables etc?
They are stock 33 size rotors.
If you are getting it for a conversion, make a list of what you need and I will give you whatever I have for $600
Hey do the front calipers come with brake lines?
If I can find my old brake lines they will, I had braided lines on the car but I kept my old ones somewhere.
are the rear rotors DBA as well?
No, they are standard but are in good condition and have only been machined recently
Hey mate, offer of $350 picked up for the front rotors, calipers (and hubs if you'll do that, not terribly fussed).
Cash in hand, can come around whenever suits. I'm in south brissy.
Leave your phone number or call/SMS me 0423 850 988
Cheers
Udi
  • 2 months later...
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
    • WRXs are a pure pleb boring car these days. You need to get an STI to even get close to what a WRX used to be.
