Hi all,
Been snooping around as a guest for awhile and now I have decided to become a member n join the happy family =)
Reason why I am posting is that I am looking to buy a used car within the next month after more searching around.
Anyone recommend any shops?
I looked at power road seems ok.
Plus I am still on my probation at work and will finish in 1 month time. Anyone know of any finance places that let you go on finance during probation?
cheers all! look forward to replies from the experienced ones.
https://www.sau.com.au/forums/topic/336449-new/
Yeah the power rd dealer is decent quality some other import dealers just from the top of my head would be SSV on princess hwy and another one on hume hwy I forgot the name but from what ive seen they have decent cars but if you go private make sure you get it checked out or check it out yourself if you know what your looking for.
https://www.sau.com.au/forums/topic/336449-new/#findComment-5441841
I've just bought mine about a month ago :D. I checked out quite a few places when looking for mine. Dealers prices were way above private sale. Ended up buying mine off a member from here. Not sure what state your from but in Vic It was hard to find a good one that was near stock. I looked at around 12 I think in total for private sale. Found problems with almost every one. Then found this one and so far its perfect :). Just take your time, dont rush into buying one straight away.
https://www.sau.com.au/forums/topic/336449-new/#findComment-5441854
If your looking at a skyline, chances are it's been modded even if it looks stock. Save yourself the money (because you will probably end doing the same mods) and buy a lightly modified one off a member on the forum, someone that actually cares for their car!
https://www.sau.com.au/forums/topic/336449-new/#findComment-5441924
Hi Baruna,
Nice to meet you and welcome to the forum.
I brought mine from a private dealer but mine is 100% stock (It's a GTv so no one bothers with them cos they're non turbo)
There is another import yard on Edwardes Road Reservoir, just down from BMSRUS (BMW Wreckers) never dealt with them but I've noticed them a few times when getting parts for my Beamer.
I'd agree with everyone else, check out the For Sales section on the forum. Depending on what you're looking at spending, one of the girls is selling her pearl white R34 for 15,000 from Vic
https://www.sau.com.au/forums/topic/336449-new/#findComment-5442658
Hi Hi everyone,
thanks for all the feedback! its great that the people in this forum are so caring.
Cause I am still on work probation, my banker suggests me I get a loan (as I require some $$$$) after my probation is up.
So...probably won't get one for about a month from now...
Didn't know there was a seller section in this forum as well, thanks for the heads up.
https://www.sau.com.au/forums/topic/336449-new/#findComment-5443872
  Baruna said:
Hi Hi everyone,
http://www.skylinesaustralia.com/forums/Sa...s-only-f56.html
https://www.sau.com.au/forums/topic/336449-new/#findComment-5444110
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
