Yeah the original r33 gtr ones are 9 inch wide and with r32 ones they need to be able to clear brembos. i think v-spec ones will but not normal ones.
I need some asap guys anything that will fit a skyline, falcon, supra, hiace that will clear brembos and are 7-8inch wide with roadworthy tyres!!!!!
Come on someone has to have a set of rims that will work for me. 17x8 or 18x8 with roadworthy tyres,
must clear brembos.
PLEASE PLEASE PLEASE PLEASE PLEASE PLEASE PLEASE PLEASE PLEASE PLEASE PLEASE
Otherwise engineering is gonna have to occur!!!!!!
must clear brembos.
I have GTR R32 after market 17" x 8 rims with *new* tyres (been through Dickson pits twice) - How long fo you need them ?
S!N.
2 weeks not going to happen (GTR is leaving town). 1 week MAX! back by nxt Friday.
PS. You burn em you buy em.
Edited by Sinista32
Given it's 4WD, be VERY SURE they aren't different rolling diameters. This is including tyre profile.
If they are, I'd suggest pulling the ATTESSA fuse before you take it to Dickson, but this is also illadvised.
good to hear you got something finally!
just a quick note too, pulling attesa fuse wont work in R33/34 GTR or ANY stagea. that trick only works in the R32 which has a differently controlled system. the front will still get power and i have been told it can also do damage. only safe way to disable 4wd is to remove the front driveshaft (4 bolts)
D.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
