Hey all
Up for sale is my built r32 four door, Have thought about it for a while but have decided it needs to go, Due to work commitmence and me buying another car which i need to pick up in Japan, this one needs to go.
I have the engine advertised as a seperate item so can sell engine and shell seperate but would prefur to sell as complete.
BODY MAY NOT LOOK IMPRESSIVE BUT EVERYTHING HAS BEEN DONE TO MAKE THIS CAR GO HARD HANDLE AND STOP !!
AND YES IT IS SA REGISTED! AND WILL COME WITH 3 MONTHS REGO.
ITEM : 1989 R32 FOUR DOOR, SILVER
CONDITION : ENGINE IS BRAND NEW, AND OTHER AFTER MARKET PARTS ARE LESS THEN 2000KM OLD.
PRICE : $19K ONO FOR EVERYTHING
CONTACT : PM ME
ENGINE RB24 ( BOTTOM END )
BOTTOM END IS BRAND NEW
SPEEDLAB CUSTOM RB24 ( CUSTOM MACHINED R34 GTR CRANK )
GRUB SCREWED CRANK
LINISHED CRANK
EAGLE RODS
TOMEI PISTONS
ARP RACE SERIES STUDS
TOMEI RINGS
PISTONS HAVE BEEN TEFLON COATED
FRESH LINE BORE AND HONE
ACL RACE SERIES MAIN AND ROD BEARINGS
CUSTOM SUMP BAFFLES WITH TRAP DOORS
CUSTOM 9L SUMP
N1 OIL PUMP
N1 WATER PUMP
CUSTOM HKS 1.2mm HEAD GASKET
HKS FUEL RAIL
NISMO ENGINE MOUNTS
THIS BOTTOM END HAS BEEN MADE TO STAND BIG HP AND BIG RPM. ONLY TOP QUALITY PARTS FROM JAPAN, USED AND THE BEST MACHINING HAS BEEN DONE.
THIS BOTTOM END HAS COST ME BIG $$$
ENGINE ( HEAD )
FULL RACE PORTING
JUN 272 – 10.8mm LIFT ( BIG ) INLET AND EXHAUST CAMS
JJR ADJUSTABLE CAM GEARS
TOMEI SPRINGS
TOMEI BUCKETS
GREDDY TIMING BELT
CUSTOM OIL DRAIN MACHINED FROM THE BACK OF THE HEAD TO SUMP.
CUSTOM PAINTED ENGINE COVERS
THIS HEAD IS TO SUIT ABOVE BOTTOM END, HAS BEEN FULL PORTED WITH BIG CAMS, LIFTERS, TOMEI SHIMS, TOMEI SPRINGS,
THIS HEAD HAS HAD OVER $7K SPENT ON IT IN MACHINING AND PARTS FROM JAPAN.
I HAVE ALSO HAD A CUSTOM RB26 INLET PLENUM MADE WHICH USES THE GTR PLENUM & 6 X THROTTLE BODIES AND SO ON.
ENGINE ( PERFORMANCE / FUN STUFF )
GENUINE HKS 25/30 ( DONE 2000KM SINCE NEW )
XSPEED JAPAN STAINLESS LOWMOUNT EXHAUST MANIFOLD
HKS DUMP ( SERIES 2 WITH LARGER GATE OUTLET )
AUTRONIC SM4 ECU, FULL CUSTOM WIRING AND SENSORS
587cc SIEMANS INJECTORS BRAND NEW
TOP SECRET FUEL REG IN TOP SECRET GOLD
OS GIKEN TWIN PLATE, USED FOR 3000KM IN GREAT CONDITION
SPEEDLAB DRAG COOLER ( 600 X 320 X 115 ) BIG!
SPEEDLAB CUSTOM INTERCOOLER PIPING AND INTAKE PIPE
SPEEDLAB OIL COOLER AND LINES
CAR ITSELF
INTERIOUR IS IN DECENT CONDITION FOR AGE
EXTERIOUR IS IN OK CONDITION FOR AGE, COUPLE DENTS / SCRATCHES
PARTS ON CAR AS FOLLOWS
CEFIRO CROSS MEMBER ( SITS THE ENGINE 18mm LOWER FOR BETTER GRAVITY )
KAAZ 2 WAY DIFF CENTRE
GTR DIFF CASING ( BETTER COOLING AND MORE OIL )
SOLID REAR FRAME BUSHES
SOILD DIFF MOUNT
CUSCO COMP COIL OVERS
CUSCO FRONT AND REAR STRUT BARS
CUSCO BRAKE MASTER STOPPER
CUSCO REAR UPPER ADJUSTABLE ARMS
ARC CASTER ARMS
EXTRA LOCK STEERING KNUCKLES AND ARMS ( FORGOT BRAND BUT THERE JAP )
R32 GTR CALIPERS AND DISCS ALL ROUND
TOP SECRET BRAKE PADS
D2 HYDROLIC HAND BRAKE AND CUSTOM LINES
BOSCH 044
CUSTOM SWIRL POT IN BOOT
N1 HEAD LIGHTS
MOMO STEERING WHEEL
HKS BOOST GAUGE
N1 BONNET LIP
3 INCH EXHAUST
THERE IS OVER $10k IN AFTERMARKET SUSPENSION, DIFF, BRAKES, BARS AND OTHER PARTS ON THIS CAR, GREAT STREET / DRIFT STARTER WITH ALOT OF POTENTIAL.
Would make an awsome streeter or track car !
PICS : BELOW, WERE TAKEN ON MY PHONE
https://www.sau.com.au/forums/topic/336457-built-rb24-r32-four-door/
Gets tuned this coming thurs / friday, With the 25/30 should make 240 / 260 RWKW and be an animal with awsome response and down low torque. No reason why with bigger turbo it wouldnt make 350 / 400 RWKW all day long. I will post the results once i have them.
awesome car man, ive got this engine combo in my car too...never skips a beat. Wish i had the gtr inlet setup though! tidy... :)
what parts are needed for that to work?
goodluck with sale! car looks tough.
Hey mate
Cheers for the comments,
Alot of time went into the rb26 inlet and throttle bodies, Need to cut down the standard rb20 intake and weld on the gtr throttle bodies , then make sure they are inline / fit 100% as well as injectors and so on, then weld the rb26 water outlet where the standard rb20 one sits , Very complicated but works a dream and very very rare ( i have only seen one other in Japan which is where i had got this idea from ) once thats all done and everything fits / lines up you need to make custom fittings under the plenum to run your brake booster and so on and if you decide to run cold start like myself then you need to run custom fittings and hose from each inlet and so on.
Complicated but awsome and different which is why i done it.
Cheers
Car currently has its run in tune ( need to do 500KM or so ) then goes for its full tune this coming tuesday :-)
be interested to see what it makes, have a similar set up and mine has 270kw on a real rich tune, if you can get a video up so we can hear the beast as well as dyno sheets torque curve should be agressive, free bump
Will put video up of tune on tuesday night.
For those asking comp ratio is 8:5 - 1
Have added extra pics below for coil overs, caster arms, upper arms and so on plus some other parts ( excuse the dust / dirt needs a clean )
Due to the big cams, I have installed an electric brake vaccume pump to assist with the brakes ( full billet pump $700 worth ! )
May also swap for a GTR
Edited by stylz7
Car goes on rollers today for its tune will post video / results tonight
awsome looking forward to the results, and good decision on the 33GTR seats, guys they retail at about $700 a set and are a fantastic upgrade not only in comfort but looks great from the camera too. some one get yourself a bargain
Hey all
Sorry about the late reply, currently interstate for work and havnt had much time to come on here.
CAR IS FINALLY FINISHED
270RWKW AT 20psi AND OVER 700NM TORQUE ( TUNER SAYS ITS AN ANIMAL ON HEAT ) WILL PUT DYNO SHEET UP ONCE IM HOME ON SUNDAY
WILL ALSO PUT VIDEO UP THAT THE TUNER TOOK
Cheers
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
