Some people are asking for me to drop my price and take parts off so below is what im willing to do.
$16K as is minus GTR rims and cusco coil overs ( happy to fit standard suspension and rims if you bring them to me )
Can take other parts off but prefer not to do so.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
