it'll mainly affect idle. if the rest of the map is good then it should idle much better. when i went from stockers to 555s i used the settings i posted on the previous page (albeit with a pfc) and it started straight away and ran perfectly, even drove it that way for a few weeks.
I can't see anything on the page?
It says the part about:
"This is by far my most popular addition, a preliminary version has been in circulation to Nistune users for some time. So those who don't use Nistune, here it is"
But then bellow it is a white screen?
Everything else on the site looks to work though. Good website by the way man, you do it yourself?
dunno bout every voltage but it should be close enough. im assuming when you enter +.18 into the power fc it just uses the same correction accross the board
yea in the pfc there are the two columns(injector) that you enter the change in size% and one for the change in ms...this is on the hand controller
Now noticed in datalogit there is the same two columns as the hc and also an Inj lag(ms) vs. batt V table similar to the Vipec table so do you adjust anything in this table when you change the injectors or just the two column (injectors) table and leave it at that??
PM-R33 .... maybe vipec has this same overall setting change in the software so you dont need to change that actual table you mentioned??
U don't have to adjust the ms/Volt table unless ur AFR changes when electical loads are applied to the engine.
Then to set it disconnect ur alternator and as the volt slowly decrease set the ms/Volt table at the current Voltage to keep the AFR at idle constant.
what about the minimum injector pulse width?
I've adjusted my lag time to work well, but when I'm say cruising on a slight down hill, and only slightly touch the accelerator, i get spluttering, i watched and noticed my AFR's leaned out in this situation.
Am i correct in thinking it's got more to do with minimum pulse width than injector lag times?
fine with no throttle, fine with normal throttle. It's just that really low almost like resting the foot on the pedal kind of throttle.
When i say lean i mean about 17-18:1
14.7 with low throttle, 20+:1 (no fuel) with no throttle. But just the interchange between throttle and no throttle basically.
using NIStune with seimens deka injectors
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
