clearing few things i have lying around need the cash to fund my rb20 bluebird
r32 rad support
Pair of r32 gts-t mags
r32 Bilstein Shocks and springs sit stiff as fronts only
Rb26 3inc Front pipe 2into 1
R32 stock gts-t fronts seats in great condition
R32 gtr rear seat
r32 GTR 3.5inc exhaust to 5inc tip
COmplete 32gtr interior minus fronts seats and cluster, all dash plastics 3 guages in console belts ect
r32 gtr Clutch master and brake master with pedal assembly and lines to slave ect
r32 GTR gearbox
r32 fuel tank
Ill add more pics and parts when i get a chance or text me
im open to offers on it all i want it gone and want the room
can do a deal need rb20det highmount, z32 air flow sensor or trx panels
contact 0431741272
located northern suburbs and dont mind shipping
https://www.sau.com.au/forums/topic/336484-r32-gtrgts-t-parts/
there of a 32 gtr the shocks
adelaide northern suburbs is location
for those that pm'd me i can only send 1 pm a day for some reason so might take a while to reply to them all
$100 for rad with bonnet catch i dont mind freight but would need to look into how i would send it
the cooler is just stock r32 gtr kit with all pipes mounts and bov
i have gtr injectors
gtr fuel pump
and full cooler kit available too if anyone needing any
How much for the injectors and fuel pump mate sent to western australia 6064? how condition are both items in and how much kms roughly
r32 rad support
R32 gtr rear seat
r32 GTR gearbox
r32 fuel tank
contact 0431741272
hey mate after the rad support plus postage to canberra.
pm me please
