Hey there, I have a 93' R32 GTR. When i bought the car, i noticed it had white inserts for the guages in the dash cluster. Anyway, some of the gauges aren't working. I'm assuming the person who installed it had no idea how to hook everything back up, or the dash is faulty.
The oil pressure gauge goes to the max when i start the car up, the petrol gauge doesn't move - it sits at 3/4 full no matter what, and the speed-o is off by 10km (reading higher than actual speed). Where should i take my car to get these corrected? Just a regular auto electrician, or should i be looking for someone who specialises in imports?
I had a quick search but couldn't find anything useful, so i'm sorry if this has come up before!
Thanks in advance for any help! :P
Mick, it's not that difficult to take the dash cluster out yourself. It sounds like whoever put int he white inserts didn't connect things properly. Also the inserts sometimes are sitting flush and that can cause problems as well. I'm experiencing both speedo and tacho issues with my car so have taken out my dash cluster quite a few times.
It sounds to me like the connectors at the back of the cluster are not clicked in all the way. That would be where I'd start looking at first.
Alright ill give that a go. Do i need to be worried about the position of the needles or anything? If i find they are not connected properly, and i reconnect them - should it be good to go, and accurate? Thanks mate
Not sure on the needles part, but the electronics determine where they should be. So if they get moved manually, I'd imagine the electronic parts would then correct them to where they should be. That's only my guess however, so don't take that as being fact.
i had to go to a specialist guage mob - like those that adjust speedos etc
if the needles are replaced in the wrong spot they will not auto correct themselves - especially on a 32 which uses the mechanical speedo
Ahh cool, would you suggest going where you went? I'm in the city in sydney, not sure of any places i can go as of yet. Cheers for the info :dry:
Possibility that the wire from the sender has been pinched and is grounding somewhere (sender is a variable resistance to earth).
Maybe the float for the sender (in the fuel tank) is broken.
You can move the needle on its spindle. Manually move the needle to point to, say, 60, then lock the rear wheel in place and GENTLY rotate the needle on its spindle back to 50.
Thanks in advance for any help! :happy:
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
