Hi mates :P
I'm looking for some one that can build a skyline head for about 800hp @ 10000 rpm's. please provide contact
Can you list items that i would need before i spend the big bucks. :)
  • Replies 60
Posted Images
this should do it for u if u can get more details, they have come down in price abit as well i was looking around a lil while ago and they were about 1000 more.
http://www.spoolimports.com/content/NISSAN...EADSFORSALE.asp
Depends what you want done.
Are you after parts or just head machining?
To keep it simple, i think it would be best for the machinist to pick the parts and do the work. I just pay. Port and polish valves, guides, springs, retainers combustion chamber reshape, valave angle job, solid lifters, cams, etc.
bullet in SA, its where most decent 26 heads from around the country end up.... best work ive seen on rb26 heads so far. CNC ftw everytime
http://www.bulletcylinderheads.com.au/nissan_rb26.php
+1 for Paul @ Red R Racing
[email protected]
top quality workmenship and knowledge..
thanks everyone, i contacted paul I'm giving hin all my specs now, for a price quote. Anyone have an idea on the price for machining and parts.
Thanks again mate
Heres another example of his fine work this is his stage 3 race porting. I have currently have my engine being built buy paul now and all i can say awesome workmanship and knowledge and top bloke.
Hi mates :P
hi mate i just built my motor for that power plus.. Envy imports at brookvale 9907 4144 they have built plenty of these heads mine will rev to about 10 500 rpms give herman a call and get the details off him iv done all the port work bigger clearances for the cams which are 290 degree jun cams all the valves buckets shims etc go to envydyno on youtube to see there work
10500 rpm, craazy, hope your oil pump and bottom end will hold up
The best place i found so far is http://www.theoldone.com/components/cylinderheads/skyline/
I think these guy's are the best. check it out and let me know. the work is clean as it can ever be. A mirror shine mate.
I hope you are not deciding what is "best" based on a clean, mirror shine... :P You need to use their custom pistons with that head too.
Are you located in Australia? I would definitely consider a local company before sourcing something overseas.
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
