How to install a Buddy Club VCT controller
I'm using an RB20 ECU Nistune.on my RB25det
I just need to know where to install the
grey wire (vct input)
yellow wire (vct output)
green wire (RPM)
and do All of the go to the wiring loom at the ECU?
also at which RPM should be set?
I assume you still have the R33 loom and plug - here is a pinout diagram (or you can google for others if you habve a different model). Don't know the change over points - its about 1500 and 5000 - someone may correct me - but ideally you do a dyno run with vct on and another with it off and then you can see the ideal changeover points for your engine.
http://wiki.r31skylineclub.com/images/7/72...ECU_Pinouts.jpg
arnt the buddy club ones only for v tec? as in one switch point . on(Or off) above a certian rpm and off (or on ) below said rpm . not s switch pionts like a rb25det needs
or do the have a skyline one now?
