Confirmation with Just Car over the phone told me that if you are not legally driving the car you have no cover what so ever. Third Party and Comprehensive is void.....
Just like i thought. I would just buy a shitter and drive that for 6 months till you get you license. You will have a true apprecaition of your new car then ;) . Dont risk damaging your financial record for life by driving it.
easiest thing to do is apply for an exemption at the RTA you will need to write a compelling letter showing you looked on the site and called RTA and was told is not on the list but later found out that it was on the list so the RTA was the cause you were miss informed and now cannot sell the car as you would be at a great financial loss and the car is also used as a family car by your parents
this should be enough grounds for you to get an exemption
worst that can happen they refuse you one and you have to go with the little 500 banger till your on full license
don't think they'll buy that reason. The RTA ruling is pretty clear on that ..if it's registered under his name, then it will not be considered a family car. It has to be registered under either parent, then u can argue that it's the sole family car and that he's applying for exemption to be allowed to drive the car.
Garage the V35, and go buy a $500 shitter to drive legally in the meantime: at least that way if someting does happen, you only wreck a crappy car with no insurance, rather than a $26k car with no valid insurance.
Agreed.
no sense in driving around with out insurance for you and other drivers.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
    • I'm not sure where you are, but United Terrey Hills has E85.
