I used Motul Chrono 300V 5w/30 for the first two service intervals
I won a shitload of Mobil 1 0w/40 in a competition so I'm using that for the time being, afaik it's fine & asked a few mechanics who work on 350/370z's say it should be fine with the VQ engine
I guess any fully synthetic with the proper viscosity range :P
it's fairly straight forward to change the oil in these cars so definitely DIY can save you a few bucks
i change every 5000km, so castrol edge - syn 5w30 is fine with me. I've never tracked my car ...so wouldn't know if theres any difference.
used motul chrono and royal purple before and cant honestly say i noticed the difference in 65/35 city highway driving.
look in your service manual for recommended viscosity on the HR engines
Edited by fcruz3r
Thanks I think I'll try the Motul 5W30 and then switch to the castrol afterwards, problem is I didnt even get a service book. This is my first import and assumed it would be normal.
Edited by mystic
mine didn't come with a service book either...but every 2nd hand car i buy whether import or locally delivered...i always do the fluids and trans oil straight away....more for peace of mind
When i was getting my v36 comlied i asked the garage to change the oil, they did to a Penrite 0w-40 full synthetic. I wanted them to use Mobil 1 fully syn but they couldn't get it and i lived too far away to buy it myself and drive it down there to give it to them but i will be changing it soon within the next 3k so not too much of an issue. I cant say anything bad about Penrite but I've always been a stickler for Mobil 1 but i also dont use my car on the track just drive to work and back so it never or rarely gets a flogging although highway driving is what i do a bit more of. :down:
LEA Insurance Brokers Pty Ltd AFSL No. 241418
LEA Life Brokers Pty Ltd AFSL AR No. 289102
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though eg https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
    • Yes, multi relays needed, and possibly a diode. I'm not actually going to think about it though.
