hey guys putting my car up for sale specs are:
EOI: 1998 S14a luxury edition
Ouside:
Re-spray in Mazda pearl white with black roof paint only 2years old
M sport front bar
Vertex side skirts and rear bar
Enkie G-spec 18x9.5 +18 all round very rare haven’t seen another set before.
Front kuhmo 95% tread, Toyo Proxie 4 rears about 80% tread 235/40 all around
8000km HID head lights
King springs low,
Most of the bushes in the front have been replaced.
Driveline/Brakes:
Factory ABS,
Factory LSD still tight as.
Front, Standard 4 spot callipers.
Rear, R34 GTT, 290mm DBA rotors with Endless pads, also now has Drum handbrake set up also.
Inside:
Steelmate 2way pagers style alarm system, with 1.5km range
Factory 2way electric sunroof doesn’t leak!!
Factory dual SRS Airbags
52mm electronic Boost gauge
will come with Standard leather steering in great condition
Power windows
Power mirrors
Seats, door trim etc. Mint as
Razor gear knob
Tinted windows.
Alpine head unit with IPod cable
Engine:
Factory blacktop SR20DET 116,XXX kms on engine and body
Nismo front strut brace
K&N pod,
Z32 AFM
Splitfire coil packs
550cc nismo injectors
S14 turbo high flow same as GT2871 with 84. Rear housing better top end power
X-force dump pipe with full 3inch exhaust with straight twin pipes out the back,
600x300x76 front mount intercooler
Nistune ecu
New O2 sensor
New spark plugs
Heavy duty clutch
Making 210rwkw on 16psi,
Car Is serviced every 5000kms just had new plugs and gearbox and diff oil (redline shockproof oil)
This S14 is in very good condition well looked after washed at least once a week, always run on mobil 8000 fuel. Car was auto from factory and was only made manual at 90,000kms so engine is nice and strong, never been taken to the track. Most mods engine wish only 5000kms old, car has never missed a beat at all, always starts and runs like a dream
reason for sale, im looking to hit the track and dont wanna wreck such a nice car,
Pics:
Price: $17k ono or swaps plus cash my way, maybe S13, 180sx etc..
cheers,mike
https://www.sau.com.au/forums/topic/336566-s14a-luxury-spec/
* R32 gtr lsd, half shafts.
* Top secret coilovers (3 way adjustable)
* Mines re-mapped computer, very conservative tune at 210 rwkw
* Z32 airflow meter
* Walbro in tank fuel pump
* Spitfire coil pack
* Big aluminium radiator
* Blitz cooler and piping
* Adjustable boost tap
* Engine Dampener
* Just Jap Racing front strut brace
* Brand new gates racing blue timing belt with clear cover
* Adjustable cam gear
* Apexi pod airfilter with fiberglass cover
* Front n back adjustable camber arms
* Adujustable Caster arms
* Hiflow turbo
* Lightened nismo flywheel
* Excedy heavy duty clutch
* Nismo cluster, nismo gear knob and nismo floor mats, (I have the standard skyline floor mats in brand new condition)
* Boost and water temp gauges
* Hicas lock bar
* Solid rear cradle bushes
* Full exhaust from japan with high flow cat and custom dump pipe
* Big body kit with stealth boot lip
* 25mm spacers on the back and 30mm on the front
* front- 17x9 rear 17x9.5 with new tyres all round
* Jappo head deck with jbl 6inch, alpine 6x9, jbl amp , pioneer sub
All these mods have been engineered and i have engineers certificate
i service it every 8000km and use motul motor oil and royal purple gearbox oil..
I also have the stock diff and half shafts
32 gtr control arms and hubs
400r front bar with add on lip
32 gtr handbrake cables
r33 s2 stock wing
You can call or msg me on 0410633612
Attached thumbnail(s)
Reduced 80%
720 x 482 (81.69K)
Reduced 93%
2048 x 1536 (392.83K)
Reduced 91%
1600 x 1200 (311.78K)
Reduced 93%
2048 x 1536 (298.24K)
Reduced 93%
2048 x 1536 (331.49K)
Reduced 93%
2048 x 1536 (351.48K)
Reduced 93%
2048 x 1536 (382.43K)
Reduced 93%
2048 x 1536 (247.14K)
Reduced 93%
2048 x 1536 (341K)
Reduced 93%
2048 x 1536 (299.87K)
    • I don't really know general street pads too well, but there is no reason you can't get a low dust, long wearing, no squeal pad that works for those calipers at a reasonable price....they would just be a low end to medium price daily style pad.  If new pads don't have much bite or they loose it over time, it is probably just the pad glazing up which you can fix by giving them a good thrashing every now and then (or get the mechanic to deglaze them at next service) Track or semi track pads are where you have to put up with excessive dust (and potentially squealing as a side effect of that) in return for good bite and performance when very hot. Street pads have nothing like that sort of punishment, even long downhills with the brakes on are easier than a track session
    • lol yeah I'll check that, reminds me of the LDV thread!  I don't think that is the problem here, the starter doesn't even solenoid click. I did do a super quick test by removing the starter motor's power cable from the engine bay fuse box and the battery voltage was still 10v, so something super fishy is going on. BTW here is a R33 fuse box table I threw together from a few sources....use at own risk! R33 Fuse Box and Sources.xlsx
    • Johnny's approach, throw all the Nissan electronics into the trash. Best thing I've done to my shit box, go DBW.
    • Sounds like the JAX guys must have installed some really awful pads, are they BenShit/BenDicks pads by any chance?
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
