around the passenger side strut in the loom running back from the headlights there should be a couple of power wires, pretty sure there's constant and switched there. these are ones i used to get the comp up and running on my 25 conversion in my laurel. and my ceff has the same looking plug, from memory it was a 6 or 8 pin rectangle shape
That plug is currently in use.
Dunno if its for the ECU power - I paid a cashie to wire it up but he did use that plug.
If it's being used for something else, is it stable enough to run all the power I need off the one or two spares in that plug ?
Edited by Nic_A31
Whatever you do don't use the ciggie lighter plug (i'm sure u won't). My touchscreen DVD screen had a loose connection with the power source from headunit so I got lazy and soldered it to the ciggie plug wires. Well that ended up nicely with smoke and $200 down the drain :geek:
