hey guys,
i have a love for all things mechanical and im interested in learning as much as i can about engine building, turbo selection and suspension / handling (i was an apprentice mechanic for nearly 2yrs before leaving to persue a career in youthwork).
Iam having difficulty finding good up to date reading
could you recommend books that i could nerd up on that are easy to understand and where they could be purchased from
thankyou
https://www.sau.com.au/forums/topic/336578-knowledge-in-book-form/
hey guys,
thankyou
If you're in Sydney, you can go over to Express Publications 2 Stanley St Silverwater.
Ask for back issues of High Performance Imports > Performance Imports Magazines > sit yourself down in the front lounge area > pick what you want from the articles in each mag > pay $5 per mag.
What I try NOT to look at, is the receptionist's cleavage each time she leans over & hands me another bunch of mags. :banana:
I have so many engineering and automotive texts, here are a few of my favs:
Local author who knows his stuff, his other books are good too.
Carroll Smith is a legendary race engineer who helped Alan Moffat back in the day. All his titles are great!
Nice little book with some great info and pics of the fantastic F1 turbo engines.
Some detailed analysis of the best engines of all time.
Picked this one up at a car show recently, its newly published... nice summary of skylines.
all of my knowledge is based from online reading (and being wrong in some discussions) and doing it myself (and getting it wrong), after a while you get things right and your confidence builds from there and things start to make sense on their own, almost like a mechanical logic.
3 engine rebuilds later, countless turbo swaps, tuning, wiring, replacing parts etc etc.. it all comes together in the end. you pay for your mistakes, but those mistakes pay for your experience and IMO experience is the best way to learn.
Hmmm...
...a bit like getting all the karate black belt moves from a martial arts book?
Your comment is worthy of note!!! tick
Hmmm...
thats pretty much it.
even listened to a conversation between a mechanic and someone knowledgeable about mechanics? you can always tell which is which.
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
    • Not great at getting the camera out fast enough for cars driving. Even in traffic. S15 is in front of the kei truck.
