Hills Cruise on Sat 14th Sept
U spin me right round , right round like a red rocket baby.:lol: hehe
Yeah guys great day out, maybe next time we should take a barbie q and have some snags and chops etc.
Was a top cruise cant wait to see the video work of the day, thanks to W.4.S.P for coming out with his bro to enjoy they day and welcome to him. Thanks to Munro for organising the day and thanks to all that turned up for a great day out even if i was totaly buggered after all that cruising. How about that blowout on that yellow van, that was some scary sh*t.
"when the green flag drops the bullsh1t stops"
Mr dizzyness over and out.:burnout:
Thanks for the great cruise!
Tip for the newbies like me......when Munro tells everyone to watch out when they get to the crests just before Birdwood and make sure you slow down for bridge MAKE SURE YOU LISTEN!! Slow down BEFORE the bridge and not when you are just about on it!! After my 4 wheel slide on the bridge :D I decided that the rest of the day would just be a casual cruise.
What song was I listening to at the time??.....Out of Control by The Chemical Brothers!! Might have to save that track for the straight stuff and not the twisty stuff.
Looking forward to the next one.....:burnout:
Hi doglet,
We all learn from experiences, and that's why I have my son as passenger, so he'll know that it is easy to make mistakes. You have to watch for all road signs, and if there is none, you need to judge very carefully the road conditions. Need to be extra carefully in wet conditions as well. Also no matter how carefully you may drive anywhere, there would another driver who make mistake coming the other way! **** happens!!!!!:uh-huh:
Graham
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
