Hey all.
I'm changing calipers on my Silvia and these two Hawk compounds are cost effective in the pad size I'm going to be running.
Just wondering if anyone has run both and can comment on them? The car is a full weight S14 so I'm worried the DTC-60s might be overkill but on the makeshift chart on Hawk's website they list them as both operating from the same lower theshold but with the DTC-60s killing the HT-10s in upper temperature limit.
Does the DTC series simply superseed the HT series?
https://www.sau.com.au/forums/topic/336609-hawk-ht-10-vs-dtc-60/
I have run both but am not sure my results are typical. I've been assured the pads are very similar, and I used them in slightly different setups on the same car....but I found the ht10 terrible and the dtc60 excellent (see avatar.....).
Maybe iI was above the upper limit of the ht10 but under the limit for dtc60.
In any case, I would buy the dtc60 again in a heartbeat if they made them for my current caliper....the dtc60 in gtr brembos gave me better fade resistance and feel than my current porsche brembo/sbs dual carbon setup which is a fiar bit larger.
I can't comment on the Dtc, but i have used the Ht-10's for the last 3 years and really like them. I find them to be very consistent over 12 laps @ Morgan Park which is apparently hard on brakes as there is not much down time for them to cool down.
I've also used HT-10's for years in Targa, and at Symmons Plains. I find them to be very consistant, and last right down to the backing plate (unlike the Pagid RS14 which starts to fall appart as it gets low). I'd be interested to compare the DTC-60's though
  • 1 month later...
sorry a little late....and I have nfi what the rear pads are, they have been in for years. they are a little more aggressive than front because I am an idiot and like a tail that swings a little under brakes
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
