just replaced the coil packs with brand new ones in an attempt to solve the misfire problem around the 5000rpm range and a bad idle but ive still got problems. im getting flat spots and minor missfires all through the rpm range when i floor it and it still misses at idle. the spark plugs are platinum and are only about 5000kms old and ive gapped them down to 0.8mm so i dont think its them.
i took a video of it and put it on youtube to help you guys see what im talking about. you can hear the bad idle best when the camera is at the exhaust
https://www.sau.com.au/forums/topic/336621-bad-idle/
Not that i can here it very clearly coz there is a dam bird chirping in the background, but it sounds like a shitty injector causing it to miss. I could be wrong as it is hard to hear.
https://www.sau.com.au/forums/topic/336621-bad-idle/#findComment-5444047
it did have a shitty injector that i changed just before i got new coil packs. i wouldnt be surprised if the others were a bit dodgey too. i was playing around with it after i started this thread and i turned the cam timing thingy all the way anticlockwise and it seemed to help... a lot! im not having as much of an issue with misfires under load now and the idle is completely smooth, so i think the timing belt has slipped over one cog on the exhaust cam. i might have to send it to some pro's to take a look at the orientation of the cam and crank
https://www.sau.com.au/forums/topic/336621-bad-idle/#findComment-5444515
    • On some cars like MR2 Turbos they're notorious for not letting the wastegate open far enough to avoid overboost, especially certain cheap downpipes. If adjusting "percentage cycle" fixes it then it's just an electronic control issue, not a hardware one.
    • Same.  It's depressing to say this but the skyline can go months on the charger between drives.
    • I often leave mine connected weeks at a time. The main one I use is the old model of this, it has 2 important features - choose battery chemistry other than lead acid (most of mine are AGM) - power supply mode which you can use to try and recover dead flat batteries as "smart" chargers often don't recognise a dead flat battery is connected https://www.projecta.com.au/products/IC10/intellicharge-10a-bat-chgr The Ctek I  use was meant to have a battery test mode as well but it doesn't work 100% of the time so I am pissed at them. The distributor did everything possible to make warranty and support difficult so I'll stay away in future. The main thing with a "trickle" charger is it has multi stage programs, ie once the battery is full it turns the current right down to just maintain the charge....in the old days we just used real "trickle" chargers for that which had a maximum output of say 500mA which was safe to just leave connected to dumb old lead batteries.
    • I've heard people claim with Just Cars (now defunct) and have been paid out, but painful process, and with Shannons, but noone I know or heard of has claimed with Enthusiast, hence I'm a bit nervous with their policy. Sure I'm "covered" but am I? is the real question
    • I have the Century CC1206 12V 1/3/6Amp 9 Stage Battery Charger. It is different from the one you linked but I don't know in what way. Their manual says that it both can be left on 24/7 and that it shouldn't be left on 24/7. Go figure ¯\_(ツ)_/¯ I haven't been game to leave it on there for more than 2 days.
