ok,
i have a r32 gtst w/350rwkw rb25.
i track my car, but with my standard r32 gtst brakes its average!
i have been looking into brembo, 33gtst, r32gtst with bigger rotors.
i have read somewhere i can run my 32 calipers with brackets to run a 324mm rotor.
whats the best option?
just run a full r33 setup?
r32 gtst with 324mm rotor?
i also herd the r33 calipers are the same as r32 calipers?
do 33 and 32 run same brake pads?
cheers
https://www.sau.com.au/forums/topic/336670-brakes/
What pads are you using? Are your rotors upgraded to slotted? Are you using braided brake lines? When was the last time you changed the brake fluid?
Any or all of these will improve the braking performance before you need to think about changing the hardware. If you still want to upgrade the hardware, the R33 GTSt is the same as the (early) R32 GT-R (296mm rotor), late R32 / R33 / R34 GT-Rs are 324mm rotors. The 324mm rotors are thicker than R32 GTS2 280mm rotors (30mm vs 28mm), so the caliper might not be able to fit over the larger disk (short of machining half the pad away). The simplest method would be the get the rotors and the matching calipers, rather than try to use adapters. They all use the same DB1170 pad.
https://www.sau.com.au/forums/topic/336670-brakes/#findComment-5445261
im running the qfm a1rms.
calipers and rotors are all factory.
lines stock
fuild not old.
im picking up some r33gtst front brake setup. i can use my qfm a1rms from my r32 brakes yeah?
cheers
https://www.sau.com.au/forums/topic/336670-brakes/#findComment-5445379
Well A1RM's up front only last about 3/4 of a track day for me, and that's a 200kw GTR. Take a backup pair when you hit Mallala so you have a pair to change during the day.
Yeah they lasted similar for me on a 200kW S14. But they delaminated and took my rotors with them.
My fault for using them for something they're not designed for though. They're great street/autocross pads.
https://www.sau.com.au/forums/topic/336670-brakes/#findComment-5449118
On my 32gtst I'm running R33gtst callipers, DBA4000 slotted rotors and Ferodo DS2500 pads. Stops on a dime and way more braking than my tyres can handle, haven't run semi's so no comment there. Also have a master cylinder stopper and braided lines all round, makes a fair difference when standing on the pedal hard.
32gtst and 33gtst callipers are pretty well the same except for longer legs on the 33gtst callipers to suit the bigger rotor.
If you tried to use the 32gtst callipers with adapter brackets and 324mm rotors, you'd have to grind a heap out of the inside of the calliper which isn't very pretty or safe, as the 33gtst callipers sit 8mm further out normally than 32gtst items.
If it's a pretty dedicated track car, I would go 32gtr callipers (dimensionally the same as 33gtst but lighter) to save on some unsprung weight.
Edited by bubba
https://www.sau.com.au/forums/topic/336670-brakes/#findComment-5449754
bam, thats what i wanted to know!
the only thing that needs to be modded on the caliper to fit the adaptors is the bolt hole, needs to be filed out like1-2mm..
thats from what i have been told
https://www.sau.com.au/forums/topic/336670-brakes/#findComment-5449769
Nothing should need to be done at all to the holes...
If fitting R34 GTT brakes (310mm rotors) there would be as they run a 14mm bolt.
R32 GTSt/GTR and R33 GTSt/GTR use 12mm bolts.
My setup bolted up with the only mod being cutting the backing plate to suit the new location of the calliper.
There are two different variations out there, one rotates the calliper 15deg (which is what I'm running), the other just offsets the calliper (I have a set of these brackets aswell for R&D purposes).
https://www.sau.com.au/forums/topic/336670-brakes/#findComment-5449816
Other option is R34 GTT calipers & discs, (310mm x 30mm). Only thing you need to do is drill 12dia. hole to 14mm on your hub and find high tensile bolts to suit. Pads are the same as 32 & 33. If you buy the 34 GTT calipers from the wreckers ask them for the bolts also. They are not off the shelf items, they may be available from Nissan, I haven't checked yet. M14x1.25 35mm long with 10mm shank (i think). pitch may be 1.5mm. Not a huge upgrade but if your 32 calipers are a bit shagged & you don't like the idea of adapter plates then there is another cheap option. Only thing is you may struggle to find a 2 piece rotor in 310mm dia. DBA don't seem to make them, maybe project mu but they are maybe $1300 a pair.
https://www.sau.com.au/forums/topic/336670-brakes/#findComment-5449853
so its a good setup?
should i go down this path?
cheers
I like it and it was cheap compared to a Brembo or even more exotic setup. Really depends on your budget and how serious about tracking the car you are.
I find the R32 GTS-T calipers to flex significantly more than the R32 GTR or R33 GTS-T calipers. You definately feel it through the pedal.
Really? Are you sure that's not the firewall flexing?
https://www.sau.com.au/forums/topic/336670-brakes/#findComment-5449999
I am using:
cpz caliper bracket & 350z 324mm rotor http://www.conceptzperformance.com/Cart/de...20118.210.80.19
r32gtr calipers, braided lines, qfm a1rm pads, master cylinder firewall brace.
fits both r32gtst and 1997 S1 stagea
https://www.sau.com.au/forums/topic/336670-brakes/#findComment-5450098
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
