For Sale
Skyline R33 series 2
list of mods
18"VR5 mags good bridgestone adrenalins
slotted rotors with blue painted calipers
cusco front strut bar
gtr rear strut bar
non hicas rear cradle
turbotech boost controller
turbosmart plumb back BOV
HKS front mount intercooler
Garret TB3401 big low mount turbo
3" stainless exhaust from turbo back
oil catch can
fuel pressure regulator
mines ECU fuel,boost and speed cut
short throw short shifter
extreme heavy duty clutch
greddy turbo timer
ISC coilovers 2000kms old
body kit
Boost gauge on pillar
oil and water temp and volt gauge in dash
sony stereo with 6x9 explode rear parcel shelf. 6" explode doors and kenwood 12"sub in boot on custom backing
alarm
Very rare factory wood grain dash and gear surround. wooden handbrake lever and gear stick knob. I have never seen this anywhere else
Ive had the car for 5 yrs and serviced every 5000kms
Last time car was on the dyno it was pulling 260rwkw with a stuffed CAS. It would do more than that now.
Its been a great car Im just moving on to better things
Bad points
I think there is a head gasket problem. The radiator overheated once I thought it might of been from the head gasket. I put a bottle of copper liquid in it and it stopped (car still boosts fine but it may need to be looked at in future) and the gearbox has a slight crunch between 1st and 2nd
Im looking at $10000 as is or $12000 with another motor and gearbox as a spare in exellent condition ready to be swapped.
Also has a taller ratio diff gets higher speeds.
If you would like to know more you can PM me or 0427999093
http://i533.photobucket.com/albums/ee334/r...ds/P1050569.jpg
http://i533.photobucket.com/albums/ee334/r...ds/P1050580.jpg
http://i533.photobucket.com/albums/ee334/r...ds/P1050577.jpg
http://i533.photobucket.com/albums/ee334/r...ds/P1050579.jpg
http://i533.photobucket.com/albums/ee334/r...ds/P1050573.jpg
http://i533.photobucket.com/albums/ee334/r...ds/P1050572.jpg
http://i533.photobucket.com/albums/ee334/r...ds/P1050575.jpg
https://www.sau.com.au/forums/topic/336674-skyline-r33-s2/
This would be a cheap car if someone fixed the head gasket themselves. I can even throw one in the sale. Otherwise if this car goes to the mechanic to get fixed the price will go back up. Car has been going strong still for the last 3 months. runnig 15psi and 260rwkw
https://www.sau.com.au/forums/topic/336674-skyline-r33-s2/#findComment-5478997
Is there water in the oil?
No water in oil. Stil drives and boosts nicely. ive been now driving it the last 4 months when i first noticed a bit of a problem. And havent had a problem again since I put the coper liquid in radiator. Its supposed to be a permenant fix for head gaskets. Thats what the mechanic suggested
https://www.sau.com.au/forums/topic/336674-skyline-r33-s2/#findComment-5504693
