Thought they were same as R32, but Sleeka Spares in Adelaide is wrecking 2 Cefiro's at the moment if you can't find one locally.
I might have a very very clean one (the one in my resto build) very soon as well.
i've been told that they sit the motor lower then r32 ones? not 100% sure on that tho...? can you let me know if you'll end up having one for sale? but i'll keep looking as well. cheers mate
Rumours are they are different, yes.
For some reason, a Cefiro crossmember is NEEDED to do an RB20DET swap into an S1x so there must be some differences.
How's $150 + Postage / $150 + I drop it off to transport company and they ship it to you, COD
http://i37.tinypic.com/2qvy1hc.jpg
EDIT: Freight will be f**k all, since trucks go Perth -> Back over East with alot less on board.
Edited by Nic_A31
done mate! so with the COD i'll just pay the bloke that drops it off? whatevas easiest for u i can just give u money for the postage or whatevas. let me know mate
Cheers, Andrew
Yeah most mid sized freight companies allow payment on delivery.
I bought a FULL black interior (4x seats, 4x door cards, centre console, etc) from SA, the chick I bought it off simply took it to a depot, filled out con note and it was done, i paid for it over the phone when they called me to say it'd arrived at their depot (across the road from work) and picked it up later on.
IMO easiest way to freight big shit.
I went with Watsons Transport but ring around, get a quote and get back to me. I work in Perth's main industrial area, so most freight companies are nearby.
Give me a ring on 0431 598 320 when you've found your carrier, or if you need dimmensions/rough weight, etc.
would u be able to just box it up and post it and i'll pay whateva that cost is? the cross member shouldnt be to big to post. only cause i work out in the sticks and being near a computer is a rare thing for me cause i dont stay at home when i'm working.
Too heavy for a box, could maybe tie it to a pallet here at work but it'd work out expensive. Is why I suggested small/medium freight companies.
TNT/Star Trak/Big companies will charge through the roof for it as it's unpackaged and shit, little companies won't give a shit, they'll chuck it on top of another pallet and charge f**k-all for it.
It's your call dude.
too heavy for a box? i've spent and received a full set of coil overs before using auspost which were in boxes and which are the same weight if not heavier then a cross member? the one i took out of my sil wasnt that heavy??
Edited by A31Ceffy
Crossmember is still longer, and a bit of an odd shape.
Aus post wont accept articles over 1 metre long.
Might have to pull out of this sale dude - probably going to sell both of my Cefiro's immediately, and need the front crossmember to keep the shell rolling. I'll keep you posted.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
