Hi Guys,
Just noticed a spot on the car which looks like little bubbles and are kind of sticking out creating a rough surface.... I assume this is rust... It is just to the left of the rear quarter window and its doing my head in!
Is this common? Anyone else had the same problem? And how can i get it off !
https://www.sau.com.au/forums/topic/336741-rust/
Ok good to see someone has also experienced it in the same place... now HOW do i get rid of it?? and just how quick will it spread if i dont get to it? Well how long do i have until it wrecks the car pretty much is what i am asking...
Any advise appreciated !
https://www.sau.com.au/forums/topic/336741-rust/#findComment-5446080
go to a panel beater. the actual amount of rust will be much larger than what is visible. a panel beater will be able to remove the rust (grind it back to where it is metal), and if it has penetrated all the way through the metal then you can have the hole welded up. if it is too big then they will cut a section out and weld a new piece in.
i recently had two bubbles of rust removed from around the rear window of the missus pulsar. this is what they did. this is also the only way to get rid of the rust.
https://www.sau.com.au/forums/topic/336741-rust/#findComment-5446203
^^^ And go over the car with that panelbeater to check over other spots. Once rectified, you can rest easy.
Next time you buy a 'Line, get VINs Fasted to check on which Japanese Prefecture the car came from. North Honshu & Hokkaido = salt!
https://www.sau.com.au/forums/topic/336741-rust/#findComment-5447884
  • 3 weeks later...
rust:
rear wheel wells
inside car forward of seats in sills. happens when the car is jacked up wrong- fix is new sills in/out affects BOTH sides
C Pillar towards rear of car where glass meets body - BOTH SIDES
rear panel under tail lights and licence plate area - more so if its had a tap.
chassis rails - especially if they are crushed.
Roof around sunroof area
thats most of mine.
the minor rust can be cut out and fixed - any competent panel shop can do that with a grinder and brass.
the major stuff - new parts.
https://www.sau.com.au/forums/topic/336741-rust/#findComment-5483039
+1!!
https://www.sau.com.au/forums/topic/336741-rust/#findComment-5483043
the reason why you have rust in certain window, boot and seam areas is because they use a sealant to stop water getting in, as it brakes down in the years water will stay there work its ways though the paint and primer and cause rust.
so in conclusion pending on age and last time it was applied reseal all these areas if you dont want water build up causing rust
https://www.sau.com.au/forums/topic/336741-rust/#findComment-5483094
Bit of a misconception that its just Northern Honshu & Hokkaido is only place for salt.
They pretty much spray salt on highways over winter in Kanto, Chubu,Kansai regions but definitely its for a longer period in Hokkaido & Tohoku.
The thing you do get down Honshu is rust from coastal areas.
https://www.sau.com.au/forums/topic/336741-rust/#findComment-5483116
Thanks Mark, for upgrading my knowledge. :ermm:
https://www.sau.com.au/forums/topic/336741-rust/#findComment-5485919
  • 5 months later...
panels are $800+ a side and then labour/paint. if you can't do it your self expect a 4 figure repair bill.
I am in process of doing mine and that is :
roof ($700)
rear drivers quarter : $800+
sills $1k set
inner B-C brace $300
rear beaver panel $300.
that is PARTS ONLY. I'm doing the removal myself.
should give you an idea.
https://www.sau.com.au/forums/topic/336741-rust/#findComment-5738701
