I am researching either running an aftermarket controller for the auto or giving up and modding an r33 gtr box to suit. I found this little box of tricks which should do the job nicely for $700 US.
http://www.avenger-valkyrie.org/documents/tcu_product2.pdf
Not sure which way to go, manual would be very nice though...
https://www.sau.com.au/forums/topic/336786-m35-gearbox-controller/
that looks like a good unit but will it fix the inherit weakness of our gearbox?
The manual all the way if you could make it work..
Whats the weakness? You mean the overheating? I dont have that problem as I disconnected the torque lock up clutch.
Ah that's right.... you have the special edition gearbox.
The rest of us have the gearbox would give up under all that torque..
So do you have to program ALL the gearbox changing from scratch with that or is there a feature where it 'learns' the factory settings first? It would be a time consuming and laborious task if it all had to be done from scratch wouldn't it? I imagine Nissan spent a lot of time and money getting the shift points right under all conditions etc.
It all works great at stock power levels but bump up the boost, add a valve body and extra clutches, wack a 3000 stally on it and it wets its pants.
It would take a few hours to install and a day to tune I guess, a lot less effort than converting to manual.
your not convincing anyone here - be the first and manual conversion this bad boy! I only wish my stagea was manual, it would be a weapon with a real manual set-up and 300kw!
Yeh Yeh, I know...
I dont want to be the first at everything, cant somebody else do some of the R+D? :(
Anyone got a good R33 gtr box laying around they will sell me cheap?
T56 will work, they are a 6 speed getrag out of mercs and bmws.
Also 350Z box will work with a modified bellhousing.
Oh, thats right, you have the pov pack rear drive, we all want to keep our awd. ;)
350z box should bolt straight up, its getting a suitable awd box, make it handle the torque and weight, and then getting it to fit that we will all have issues with. R33 gtr is the cheaper option r34 gtr is the better one.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
    • When you say basic rebuild, you mean an oem rebuild?
