  • Replies 42
there is a stigma attached to skylines so dont say we didnt warn you.
i bought my skyline because it was cheap power / plenty of parts / mods and as much as its 13 years old i still think they look fairly good.
Three kinds of people when you own a Skyline.
People who think your an irresponsible motorist because you drive a skyline
People who don't know or car about skylines or cars in general.
and finally the third and largest group, those who think your a wanker because you drive a skyline.
Be prepared for all the Adidas wardrobe, kebab eating and womans car jokes from Bogans and the general public alike.
Lol
If i had a dollar for every time I've heard, "your sister wants her car back" and "only milk and juice comes in 2 litres" I would Have an SL65 AMG black as a daily and only drive my skyline when I want to, my current daily is an SR5 Corolla Lol, 4WD power !
Edited by Nee-san
Get a GTR. They drive like nothing else, lots of power, handle extremely well and driving will no longer be a chore but a pleasure. Just make sure you get a well maintained one that at least looks fairly stock (for the cops) and isnt obnoxiously loud. You should be prepared to spend some money if things go wrong, especially if you can't do the work yourself, and more frequent servicing than for a commo or similar. I guess it depends how many kms youre gunna do as well - might not be that practicle if you do mega kms. But the same goes for any car that is any fun...
Don't get an R33 if you want X factor lool. Though even an R33 will piss all over a VT in terms of the way it drives, power and braking.
Marc is possibly the biggest failtroll of the forum. Come on this guy likes MAGNAS.
yeah but you like fatties, LOL
I think 20 years of people sliding in and out has done the most wear lol, and how can you possibly relate that to the window cable snapping?!
stiletto heels into door panels via thigh-power of course :)
i bet you excite them all!
I get paranoid when someone fat wants to sit in my car, also worried that the fact some tool steps on my shiny gtr scuff plate first rather than placing their foot outside the car.
side skirts have been broken that way before :)
To me, Skylines are hypo cars and modifying them is a must, so have PLENTY of coin stashed away somewhere. I cant stand them in stock form.
If it is going to be a daily and lived with everyday, buy an EVO.
Hope you're OK/uninjured.
Hope you've got insurance.
Repairable write-off?
yeah im ok , car is still fixable according to the insurance company , quote was $22000 its rediculous ! B pillar , roof , firewall replace and re-instate .
Hmmm...
Good you're OK
Car? Hope the robot can show that body/chassis alignment is all within the mm.
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
