hi all
im new here and have owned a r32 gtr for almost a year now and Love IT!!! i live in new zealand and dont really know anyone who can actually help me so thought someone here can being such a awesome site in all.So the mods done are very little which are catback exhaust,apexi pods with adapters,and removal of the boost restrictor now running 1 bar thats it.The problem im having is i'll start my car up let it idle warm then drive,now when driving for the first 10mins it'll run awesome hitting 1 bar exactly on my apexi boost gauge and holding,but after a few times of putting my foot down and running mint it will all of a sudden it will only boost .7 bar and no more and sorta feels like your driving with the handbrake on.It will boost 1 bar again the next day i drive it but always only for the first few putting the foot downs then back to .7bar which sucks.So i did the self diagnostics on the ecu and it gave me the flash code 34 which is the Knock Sensor code.So i rang nissan and said to the mechanic what the code was and he said that i need new knock sensors and that it doesnt mean my engines knocking ??? but it doesnt sound right i thought that code meant that your sensors are picking up knock so the ecu is cutting boost??? Ive tried new afms,a chipped ecu,new spark plugs gapped to .7mm. also with no result.its weird cos it doesnt blow smoke doesnt make any apperant knocking sounds by ear anyway idles and runs good and has good oil presure etc I cant figure it out
thanks in advance anyone who replies
my guess is your knock sensor is broken, your engine doesent need to be knocking, but also sometimes the knock sensor if too loose or too tight, will give incorrect readings.
you can test if your knock sensor is working or not, grab a wrench, and when your engine is idle, hit your engine block close to the knock sensor, you should feel your rpm drop or go higher etc. if that doesent work, do the same thing again, but when reving at about 2,5-3k rpm. if nothing happends, you could have a defective knock sensor
hopefully that will help
Jean
Jean
hey man thanks for your info will try tonight and let you know what it does . really appreciate your feed back thanks!!!!!!!!!!!!
  • 3 years later...
hi guys this is the exact issue im having with it running 1bar then dropping back to roughly .7 after 10-15mins of driving. I havnt done an ecu sefl test but I will tomorrow and see if it throws the same code. I know this is an old as thread but just wondering if anyone else has had this same issue and solved it.
I should add I have only bought the car a few days ago. it has k&n pod filters, -9 turbos, full exhaust and the boost restrictor removed. now when I picked it up it had the standard airbox and I was unaware of the upgraded turbos as was the previous owner to my knowledge as he had it advertised as standard. when I went and looked at it the first time it was warm so when I test drove it it was only getting the low boost which I thought was normal. then I got it brought to a worskshop to have a look underneath and do a comp test and once again it was warm and running low boost which I though was normal. after I fitted the pod filters I took it for a drive and noticed it was hitting 1 bar, then I noticed it dropped back to half. so today I had a look and found the restrictor had been removed, also I had a good look at the hotside and pulled the inlets right off and this is how I discovered the upgraded turbos. It also has hks actuators. I had a look at all the actuator lines and they all seem fine. I have currently just hooked the actuators straight up to the manifold (bypassing the solenoid etc) to see if it make it just stay at low boost but havnt driven it since as it was hot,
Edited by R32GTR-1
Sean, what cat have you got in it ?
I would think once you turned it off it would reset itself and give you 1 bar again, so my best guess is yours is something mechanical
To run wastegate pressure just unplug the boost solenoid, it needs power to open
im not to sure what cat it is. it is aftermarket, it looks like a highflow item but I havnt pulled it off and had a look. as for how I could tell they were -9s I could see the comp cover had some different marking on them compared to what standard turbos look like so I pulled the intakes and cooler piping off until I could read one of the little metal id tags on the core of the turbo(s) and googled the part number. also since installing the pod filters I could hear the turbos spinning down once I turn the car off every so slightly which made me think they must be ballbearing.
drove it this morning with the solenoid bypassed and it was 7 psi, pulled over after a few mins, hooked the solenoid back up and bang straight to 13-14psi and same thing after about 10-15 mins of driving back to 7.
Edited by R32GTR-1
Thanks, have been wondering whether mine were actually -9's (as i was told when i brought the car) or something else, so was just curious to how you knew.
When you unplug the solenoid shouldn't you just be getting standard wastegate pressure? and isn't that 10psi? i know when i turn my boost controller off i get around 10-11psi
Edited by Gza36
I guess it's still the stock ecu.
When cold, the stock ecu retards the IGN and so you will see higher boost.
It's very obvious, even without planting the foot you'll hear the turbos working harder and the BOV's puffing on gear changes.
But as soon as she reaches operating temp, it's back to stock IGN timing.
There was a thread a few months back where blokes with Nistune complained of a similar problem.
A kind person showed how to alter some parameter and then no more cold engine IGN retard.
Might be worth a thread dig.
ok guys can update this a little bit now. yes I know what pinging sounds like and I havnt heard it ping at all. also tonight it seemed it didn't need to cool down for it to change to high boost again. left home went to a mates house about 30 mins away, sure enough about 15 mins into the drive went to low boost. fot to his house sat out the front with the car idling for maybe 2 mins waiting for him to come out, left his house turned onto the main road and bang high boost again, again lasted about 15 mins then gone. then later on in the night, driving went to low boost, parked up for 10 mins or so, went back out and high boost. so that's kind of thrown the hot/cold thing out the window. and yes I have aftermarket actuators which are set to 7-8psi it seems.
another thing I noticed tonight unsure if related or not, when im going up a hill and in 5th gear doing say 80kph (so high load on the motor) the turbos shuffle?? almost sounds like the blow off valves constantly going off. like choof choof choof choof if that makes sense lol. seems somewhat strange to me and im sure it isn't right. ive had turbo cars previously and never had anything like this but this is my first twin turbo car. no matter how much I put my foot down it wont make boost just does the turbo shuffle, I have to drop back a gear and then it will pull fine.
Ok guys I have found a big connection between the low boost and the turbos shuffling when going up hill etc. So when its running low boost the turbos also shuffle like crazy. When high boost I can not get it to shuffle at all even if I try. So im thinking maybe its a timing issue ? Would also make sense as to why when ib low boost it also feels sluggish off boost even.
  • 10 months later...
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
    • ChatGPT is trash and lies about things I would not expect it to lie about considering many things it's wrong about are very easily verified with google. The S3 R33 GTR shares its steering wheel with R33 GTSTs of the same production year. Part number is 48430-26U17. I'm guessing you have to get it from a car that came with HICAS though, the ER33 is 48430-26U18, but the HR33 diagrams note that part number is still leather vs 48430-26U13 which is not leather-wrapped. They all use the same airbags, so if you need another one you can get it off basically any same year R33 or Stagea.
    • I'm going to run hard lines front to back in the future. That should help dissipate a bit more heat. If not, a fuel cooler might be next
    • No. The mark is with respect to the cam rotation. None of those things have altered it. When stationary, the cam position stays in sync with the crank position. It doesn't matter if you moved the head 4 feet up. Hence, that mark needs to stay exactly where it is.
